Replacing Oil pan gasket - JeepForum.com
post #1 of 7 Old 02-26-2011, 10:41 PM Thread Starter
deemswj92
got a 05 tj need to replace pan gasket any suggestions on easiest way to get it off, exhaust is in the way
deemswj92 is offline
post #2 of 7 Old 02-26-2011, 10:52 PM
freeskier93
Unbolt exhaust from header and cat.
freeskier93 is offline
post #3 of 7 Old 02-26-2011, 11:27 PM
havasu
On permanent vacation
havasu's Avatar
As stated above, remove the 4 bolts at the exhaust flange, just before the cats. PB Blaster works wonders to loosen up the grip as well.
I assume you are replacing your oil pan gasket due to oil leaks? If so, confirm that it is actually the pan that is leaking and not the rear main seal.
havasu is offline
post #4 of 7 Old 02-27-2011, 08:40 AM
Zeep
^^x2
JEEP THE AR-15 OF THE AUTOMOTIVE WORLD
Zeep is offline
post #5 of 7 Old 04-09-2011, 06:00 AM
scottbr
2016 JK Wrangler
Errr, what if your exhaust is welded all the way?
Originally Posted by -Deepskyy- View Post
We've made the world idiot proof, and now its full of idiots.
scottbr is offline
post #6 of 7 Old 04-09-2011, 07:27 AM
Michael_K
Michael_K's Avatar
I have written up rear main seal replacement guide and in the process, I also have done the oil pan gasket replacement.
http://www.dailydriventj.com/forum/viewtopic.php?t=811
HTH,
Michael K.
DailyDrivenTJ.com
JUST For Jeep TJ Owners Around the World!
Michael_K is offline
post #7 of 7 Old 04-09-2011, 01:23 PM
scottbr
2016 JK Wrangler
Michael, thanks for that, very helpful. I did this today, along with a manifold gasket replacement.
My exhaust is fully welded, so I had to unbolt both rear hangers and ram the whole thing forward to get it off the catalytic converter mount in order to get it far enough out of the way to get the oil pan off. I may or may not have a hernia, but I definitely have about half a cup of dirt up my nose.
Jeez, that was a pain in the ***. Next time I'll pull the engine.
Couple of tips:
Powerwash the underside of the Jeep before you do this; you will be getting up close and personal with it.
The bolts on the oil pan are mostly 7/16" with 4 1/2" ones. You'll need deep well sockets.
Safety glasses are a MUST for this job.
scottbr is offline
Replacing Oil Pan Gasket BYuen TJ Wrangler Technical Forum 3 11-28-2007 07:11 PM
Replacing D44 Gasket ?'s joppermann TJ Wrangler Technical Forum 2 08-02-2007 02:35 PM
replacing oil pan gasket, do i use gasket sealer/maker? spinnjase TJ Wrangler Technical Forum 6 03-02-2007 08:13 PM
replacing head gasket sandman'sjeep YJ Wrangler Technical Forum 9 06-20-2006 04:29 AM
Replacing a Head Gasket on a 2.5 ltr (How much $$) ieatchickens TJ Wrangler Technical Forum 11 04-07-2006 06:09 AM
