Replacing Johnny Joints with Duroflex. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Replacing Johnny Joints with Duroflex.
Zone Offroad Body and Suspension Lift Kits, Brackets, DiscFS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectSave on Warn Winches and TENOFF Promotion!
Unread 01-22-2015, 10:45 AM   #1
cmecha
replacing the johnny joints on my upper control arms with duroflex bushings, will these just drop in? http://www.metalcloak.com/2-D-x-2-L-...2.htm?CartID=1
"always upgraded, never replaced."
cmecha is online now   Reply With Quote Quick reply to this message
Unread 01-22-2015, 11:15 AM   #2
Shark_13
JJ:
http://www.currieenterprises.com/ces...t.aspx?id=1167
"a 2" mounting width"
DF:
"Fits 2 1/4" Housing"
Shark_13 is offline   Reply With Quote Quick reply to this message
Unread 01-22-2015, 11:18 AM   #3
cmecha
yeah i read that which doesn't seem to work, but i've also seen others say it does.
Unread 01-22-2015, 11:33 AM   #4
_KONG_
Only the lowers
_KONG_ is online now   Reply With Quote Quick reply to this message
Unread 01-22-2015, 11:38 AM   #5
88hatchy
Why change them?
1997 TJ - Current project: Simple-ish build
1988 Civic Hatch - Runs 12's, gets 30 mpg
88hatchy is online now   Reply With Quote Quick reply to this message
Unread 01-22-2015, 11:44 AM   #6
cmecha
Originally Posted by 88hatchy View Post
Why change them?
I got a set of Rear uppers used, and one of the balls are badly pitted due to lack of grease, so i can replace all the bushings and that one ball, or replace with Duroflex. I was just tossing around the idea. either way i got them for cheap enough it won't really matter what i do it will be worth it. now i'm just looking for the best price on parts.
Unread 01-22-2015, 11:51 AM   #7
88hatchy
It's less than half to cost to rebuild a JJ vs. a Duroflex joint.
Unread 01-22-2015, 11:54 AM   #8
cmecha
only if the ball is still good. if not your paying 20.00 for just the ball. which is where i am
Unread 01-22-2015, 11:58 AM   #9
88hatchy
Duroflex joints are $30 EACH. JJs are still cheaper.
Unread 01-22-2015, 12:53 PM   #10
cmecha
Website says 19.00
Unread 01-22-2015, 01:01 PM   #11
Jeepsr4me
Marking this cause that is a good idea and pretty cheap... I hate the rattling JJs do and those look like the ticket for what I like.
Jeepsr4me is offline   Reply With Quote Quick reply to this message
Unread 01-22-2015, 01:18 PM   #12
Imped
Imped's Avatar
You have Currie JJ's that rattle? There's a problem.....
I've never done the JJ-MC swap with the smaller JJ barrels so I can't provide any info. Give MC a call, they'll give you an answer and a solution.
OlllllllO
Float Test Build
IndyORV
Imped is online now   Reply With Quote Quick reply to this message
Unread 01-22-2015, 01:23 PM   #13
Gary2
Back when I did my switch to DF from JJs I had to replace the whole end on the uppers and just the guts on the lowers. That was a couple years ago so that may of since changed
Gary2 is online now   Reply With Quote Quick reply to this message
Unread 01-22-2015, 01:37 PM   #14
Tonellin
Just hit the JJ ball with an emory cloth it will take the piting right out of it. I was in the same boat as you, I bought a pair of neglected arms with JJ's that had seemingly never been greased. I had to replace a set of the poly bushings but the ball itself is pretty indestructible...
06 LJ Rubicon
http://www.jeepforum.com/forum/f22/lj-rubicon-build-1481013/
Tonellin is offline   Reply With Quote Quick reply to this message
Unread 01-22-2015, 01:38 PM   #15
cmecha
I hit them last night with a 00 steel wool and can't get the pitting or the melted urethane off. is there a better way to do it?
