Replacing jeep steering box with a Durango Steering box? - JeepForum.com
post #1 of 172 Old 11-21-2006, 11:16 AM Thread Starter
Beefstew
Jub Jub
Beefstew's Avatar
From what i have heard its not uncommon to put a durango steering box on a tj... appearently its better than the factory steering.
Well its that time were yet another part is breaking down... Would you guys recomend just replacing it with another jeep steering box, maybe the High performance steering box in quadretec.... or a durango
and with the durango, if any one has done this, is it a direct replacment or is there some sort of conversion kit or any thinig special that i would also need?
Beefstew is offline
post #2 of 172 Old 11-21-2006, 11:18 AM
BNovak
BNovak's Avatar
The durango box is a complete bolt on project.
Just soak the crap out of your pitman arm with penetrating oil before you get started. That's what took me the longest of this swap.
Someone else needs to chime in with the correct durango box though (or try a google search?)
-BN
'97 Forest green. ~6" total lift, 8.8, etc. 36" TSL's, winch. You get the drill.
BNovak is offline
post #3 of 172 Old 11-21-2006, 11:24 AM
dirtbagofva
2010 JK Wrangler
http://www.universityofjeep.ca/Tech/...onversion.html
have fun...now will it work on a CJ? that's my problem.
"It is a damned poor mind indeed that can't think of at least two ways of spelling any word."
Proud owner of 2010 JK, 1994 XJ and an 81 CJ-7
dirtbagofva is offline
post #4 of 172 Old 11-21-2006, 11:25 AM Thread Starter
Beefstew
Jub Jub
Beefstew's Avatar
I think its like a 98 or 99 durango box...
im not sure tho
Beefstew is offline
post #5 of 172 Old 11-21-2006, 11:29 AM
BNovak
BNovak's Avatar
im not sure tho
It was a specific motor combination though - something like th 358 with 4WD and air conditioning or something strange like that.
-BN
BNovak is offline
post #6 of 172 Old 11-21-2006, 11:42 AM
Conundrum
Conundrum's Avatar
'98 to '99 Durango with a 318.
Matt
2001 Jeep Wrangler Sport 4.0L - Amber Fire Pearl Coat
1981 DeLorean DMC-12 VIN: 2953
Conundrum is offline
post #7 of 172 Old 11-21-2006, 12:19 PM
YCP4x4
YCP4x4's Avatar
Is this stronger than the stock? I was looking to upgrade my steering components when i did the rest ( i upgraded to 35" tires)
2003 Rubicon ** SOLD **
4" Superlift
35" Mickey Thomson Baja Claws
YCP4x4 is offline
post #8 of 172 Old 11-21-2006, 01:13 PM
Conundrum
Conundrum's Avatar
Yes, it is stronger from what I've heard. I'm updating to the Durango box sometime. My stock one in leaking.
Matt
post #9 of 172 Old 11-21-2006, 02:13 PM
The Mean Fish
The Mean Fish's Avatar
The Durango box mod won't work on any 03 and newer TJ.
The Mean Fish is offline
post #10 of 172 Old 11-23-2006, 06:02 AM
davenjeip
davenjeip's Avatar
Sucks because I was going to do it on mine.
We did a Durango box swap on my buddies 2001 TJ.
Direct bolt on, although we did have to swap the pitman arm from the TJ box onto the Durango one. The lines even connected up easily with, at most, a very minimal amount of tweaking.
2003 TJ
www.davenjeip.com
davenjeip is offline
post #11 of 172 Old 11-23-2006, 05:23 PM
terrible
So what's better about the durango box? better gears? bigger bearings?
terrible is offline
post #12 of 172 Old 11-23-2006, 05:52 PM
neZZr
Lifted/Locked/Rolled/Sunk
neZZr's Avatar
I don't know that it is any stronger, but typically the reason to use the Durango box is the quicker ratio.
I'll be Savvy someday!
neZZr is offline
post #13 of 172 Old 11-23-2006, 05:58 PM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
yeah, its just a tighter ration, everythingt else is pretty much the same from what i've been told.
for some strange reason parts here cost and arm and a leg. i was gonna get a durango box, but they were 230 bucks. i had to settle for a TJ box, and it was still freakin 150. its going on tomorrow morning.
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread:
Marn is offline
post #14 of 172 Old 11-23-2006, 06:09 PM
dirtgrip
dirtgrip's Avatar
http://www.jeeps-offroad.com/forum.php?page=durango-ps
Local guy got a used box for $50.
Large vacuum leak sucking all the dead presidents out of my wallet.
dirtgrip is offline
post #15 of 172 Old 11-23-2006, 07:02 PM
miguelitojeep97
how do you know if your power steering pump is going out or your box? The pump is leaking pretty good and fluid is all over my hood, and my box is leaking too but not dripping all over my driveway.
1997 TJ 4.0 5 spd. rock track 4:1, 3.5 inch Rock Krawler 5 inch stretch long arm, 35 inch MTRs, Warn 9k, D44/30 locked with 4:88s, Vanco BIG BRAKES!!and more...
miguelitojeep97 is offline
durango steering. 99 durango 00 tj pitman arm slafferty TJ Wrangler Technical Forum 0 09-05-2009 01:28 PM
Durango steering box hughes16 TJ Wrangler Technical Forum 1 11-17-2008 08:59 AM
Will durango steering pump work with the steering box. sitdwnandhngon YJ Wrangler Technical Forum 0 08-13-2008 07:20 PM
Durango steering box + Steering box skid tjsahara1979 TJ Wrangler Technical Forum 2 05-30-2008 01:48 PM
Replacing my Power Steering Box with a durango one Rocky.ca TJ Wrangler Technical Forum 4 06-13-2007 09:41 PM
