Replacing inner axle seals on Rubicon - JeepForum.com
post #1 of 6 Old 06-24-2010, 05:25 PM Thread Starter
MikeBK
I had my gears done last year but they did not want to change the seal, if they are good don't fix em. Well now the right front seal is leaking and this guy wants to charge me to fix what he probably broke in the first place, for those of you that dont know it, they make a stupid little plastic ring that costs $1.50, it goes around the axle at the spline end to help keep the axle centered in the tube so you don't rip the seal, like this guy did. So I have new axle seals and the guides and I'm going to do this myself, is there anything I need to be looking out for when removing the locker, will I need a case spreader or just pop it out with a prybar? Any advice is appreciated.
Mike
Consider Obama the lesson many in this country need to learn, the rest of us just have to pay for it!
MikeBK is offline
post #2 of 6 Old 05-29-2013, 08:01 PM
Jimi79
Im having this problem how did you make out with changing the seals?
/l ,[____],
l---L -OlllllllO-
()_)-()_)-o-)_)
2006 Tj Rubicon on 35s
Jimi79 is offline
post #3 of 6 Old 05-29-2013, 08:12 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Stu Olson's awesome website has all kinds of information on how to work on our Jeeps with specific instructions on the D30's inner seals at http://www.stu-offroad.com/axle/d30seals/seal-1.htm.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is offline
post #4 of 6 Old 05-29-2013, 09:21 PM
Jimi79
I read that write up thanks thought Jerry, mines a dana 44 with a locker, is there much different. I just posted about it being overfull with watery oil hoping maybe that has something to do with it but i'm sure ill have to change the seals
/l ,[____],
l---L -OlllllllO-
()_)-()_)-o-)_)
Jimi79 is offline
post #5 of 6 Old 05-29-2013, 09:32 PM
deafdog
I used Stu's article as a guide when I did mine last winter. That was my first axle seal replacement, so just I followed the steps and had no problem.
I can't say I am all too fond of gear oil smell.
deafdog is offline
post #6 of 6 Old 05-30-2013, 08:36 AM
SolarOne
Has anyone been inside to potentially rip the seal?
I ask because, the OE seal began to leak on my left front axle around 30k. I drained the factory fill and replaced with 75w140 (same as the rear on my Rubicon). The issue went away, has me thinking there isn't much of a seal conditioner in the OE fill (fluid looked fresh only 30k on it). I replaced with M1 synthetic LT, not really worth the $ (Redline is cheaper). M1 is found everywhere so I'm paying for accessibility / fluid compatibility.
.. __________
./____l__[\___\___
[/---\_l___l/--OlllllllO
.(o))--(o))_(o))--(o))
SolarOne is offline
axle , seal , inner , d44 , dana 44 , replace , replacing
Am I ruined? Replacing rear axle seals on Dana 44 Sahara jeffpas TJ Wrangler Technical Forum 0 05-08-2010 03:56 PM
Rubicon Inner axle seals andy0857 TJ Wrangler Technical Forum 0 04-22-2010 07:18 AM
replacing front axle seals asbury YJ Wrangler Technical Forum 3 09-14-2009 02:03 PM
Replacing front axle seals TheDustMan YJ Wrangler Technical Forum 5 08-13-2009 04:31 PM
Replacing D30 axle seals. Any things else while I am in there? jeepjared84 YJ Wrangler Technical Forum 16 05-23-2009 08:16 PM
