Replacing fog light stalk switch with dash mounted switch? - JeepForum.com
post #1 of 8 Old 08-30-2008, 04:54 PM Thread Starter
Imped
Imped's Avatar
Hey guys, has anyone disabled the stalk-mounted fog light switch and replaced it with a dash-mounted unit? If so, please explain how to do this. Thanks in advance!
OlllllllO
IndyORV
Imped is offline
post #2 of 8 Old 08-30-2008, 05:19 PM
durango-bob
2006 WK
I've never done it, but it would be a simple matter to cut the wires going to the stalk switch and reroute them to your new switch. You will most likely have to extend them. A factory service manual is a good tool to have since it lists the wire sizes, markings, and connector locations.
durango-bob is offline
post #3 of 8 Old 08-31-2008, 10:09 AM
Pillswoj
Is this because the stalk mounted switch is Malfunctioning? If so be warned that the other functions of the switch (headlights etc) will also malfunction sooner or later.
Friends don't let Friends run Bosch
Pillswoj is offline
post #4 of 8 Old 08-31-2008, 10:16 AM
Rowingfish87
I would be interested in this as well because my stalk is malfunctioning. my fog lights turn themselves on all the time and sometimes i cant get them to turn off. should i just look into getting a new stalk? my fear is that the light stalk will be fairly pricy at the stealership and i don't look forward to ripping apart my steering column to do the replacement/install.
Rowingfish87 is offline
post #5 of 8 Old 08-31-2008, 10:20 AM Thread Starter
Imped
Imped's Avatar
It isn't malfuntioning at all....I just don't like it on the stalk. I would rather move it to a dash mounted switch, since that is way cooler, and I'm wanting to have a few switches next to each other.
OlllllllO
IndyORV
Imped is offline
post #6 of 8 Old 08-31-2008, 10:22 AM
deltabravo
This doesn't directly answer the question, but if more lights or other doo-dads that need a switch are in your future upgrade plans, here's what I did: www.4x4spod.com
(I don't use the stock fog light wiring anymore - i abandoned it and ran new wires to my new fog lights)
deltabravo is offline
post #7 of 8 Old 08-31-2008, 12:54 PM
Pillswoj
OK, then as Durango Bob said, with wiring diagrams from FSM it should be a reasonable job to relocate them.
Pillswoj is offline
post #8 of 8 Old 08-31-2008, 12:58 PM
Pillswoj
Actually, the replacement is not that bad, I had to do it on my wifes PT Cruiser (Same POS switch). For now if you leave you left turnsignal on when you shut off the jeep it should keep the fogs from coming on and killing your battery. The switch is a dealer item or search online, about $150 is I remember.
Pillswoj is offline
In dash fog light switch ? fredzle TJ Wrangler Technical Forum 7 06-20-2009 07:52 PM
Dash light switch!! RedWrangler90 YJ Wrangler Technical Forum 0 06-16-2009 10:40 AM
Fog light switch in dash? Houndmaster1 TJ Wrangler Technical Forum 6 05-31-2009 09:32 PM
Replacing head light switch scullcrusher TJ Wrangler Technical Forum 1 10-11-2008 11:20 AM
Replacing factory fog light/hl switch...difficult? DLewis TJ Wrangler Technical Forum 1 07-02-2008 12:41 PM
