Replacing exhaust manifold, have question. - JeepForum.com
post #1 of 9 Old 04-05-2010, 08:41 AM Thread Starter
MSJEEP88
I'm replacing exhaust manifold this week on 1997 tj with 4.0. I have read before about a tool or wrench needed but I cant find it now. Can anyone help ? Also would you spray bolts with pb blaster a few days before or is there something better ?
MSJEEP88 is offline
post #2 of 9 Old 04-05-2010, 09:07 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
A 9/16" or 14mm ratcheting wrench will make the job much easier.
There is not much room to work around the exhaust and intake bolts.
You should not have much trouble with rusty bolts, except for maybe the bolts that secure the header to the downpipe. I usually just cut those off.
PB blaster works ok for a penetrating fluid, but there are better options. Liquid Wrench works a little better.
Wheelin98TJ is offline
post #3 of 9 Old 04-05-2010, 09:21 AM Thread Starter
MSJEEP88
9/16" ratcheting wrench, thats what I was looking for. Thanks alot.
MSJEEP88 is offline
post #4 of 9 Old 04-05-2010, 10:49 AM
IslandTJ
I needed a "fuel disconnect" tool when I replaced my manifold.
Now Jeeping in Oregon
IslandTJ is offline
post #5 of 9 Old 04-05-2010, 11:33 AM
Wheelin98TJ
JEEP FREAK
A fuel line disconnect tool does make it easier.
You can get it from Napa for around $10.
Or you can leave the fuel line hooked up and remove the fuel rail and the injectors as one assembly. You risk tearing an o-ring doing it this way though.
post #6 of 9 Old 04-05-2010, 12:47 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
You need a 9/16"s swivel socket, extensions and a ratchet... along with special tool for fuel line release.
GOLENJEEPTJ is offline
post #7 of 9 Old 04-05-2010, 02:53 PM Thread Starter
MSJEEP88
Thanks everyone, new one will be here Tuesday just wanted to make sure I had everything I needed .
MSJEEP88 is offline
post #8 of 9 Old 04-05-2010, 04:12 PM
fire239
Where in MS. I'm in north MS. If your close, I'd help ya. I've done it a couple of times.
fire239 is offline
post #9 of 9 Old 04-06-2010, 06:43 AM Thread Starter
MSJEEP88
Saltillo, just north of Tupelo.
MSJEEP88 is offline
Replacing my crack exhaust manifold mightydog78 TJ Wrangler Technical Forum 7 08-29-2009 07:35 AM
Replacing the Exhaust Manifold on 92YJ mongowo YJ Wrangler Technical Forum 2 01-10-2009 04:52 PM
Replacing exhaust manifold. Anything else I should do at the same time? VanTheMan YJ Wrangler Technical Forum 4 03-26-2007 08:35 AM
replacing exhaust manifold, need tips rick95 YJ Wrangler Technical Forum 4 06-24-2005 10:46 AM
Replacing exhaust manifold gsdpwd TJ Wrangler Technical Forum 6 03-24-2005 06:42 PM
