Replacing exhaust manifold - JeepForum.com
post #1 of 7 Old 03-24-2005, 12:32 PM Thread Starter
gsdpwd
Is there a link on how to replace the cracked exhaust manifold on my 97 tj? I searched but couldnt find a link or a how to...
I think its just unbolt and replace, or at least thats what I am hoping...
Thanks
gsdpwd is offline
post #2 of 7 Old 03-24-2005, 12:38 PM
Dogman
Dogman's Avatar
Well, you have to remove the intake manifold too...it's not too bad at all. I haven't seen a write up, but I did it a few months ago.
Basically remove and label all connections to the intake manifold.
Disconnect fuel line
Loosen serp. belt
Remove power steering pump (not the fluid lines, just disconnect from intake manifold and move aside)
Unbolt manifold bolts.
You get the picture...
John 3:17
Dogman is offline
post #3 of 7 Old 03-24-2005, 12:43 PM Thread Starter
gsdpwd
Thanks.... I am heading to the garage to tackle this.
gsdpwd is offline
post #4 of 7 Old 03-24-2005, 12:44 PM
Dogman
Dogman's Avatar
Another thing is the tightening (torqueing) sequence of the bolts when you put it back together. I'll grab that for you. Be right back...
Dogman is offline
post #5 of 7 Old 03-24-2005, 01:33 PM
Darkstar
http://www.jeepingsingles.net/tech/manifold.asp
Hope this helps!
'99 TJ Sport, 5 speed, black/black, hard top, 31x10.50 BFG AT's on Canyon's.
Darkstar is offline
post #6 of 7 Old 03-24-2005, 06:06 PM Thread Starter
gsdpwd
Well I just got done. It took me about 4 hrs with the help of two of my friends who are mechanically inclined. What a pain in the .... Luckily I had a lift to use or it would have been even more of a nightmare. Well, I am glad its done and the jeep runs and sounds great again. Thanks for your help.
gsdpwd is offline
post #7 of 7 Old 03-24-2005, 06:42 PM
Jim Shanks
Jim Shanks's Avatar
Glad it all went fine, some people have issues with getting the intake fully seated. Sounds like you nailed it though.
Congrats,
Jim
"Cracked Cow" '01TonTJ2a, Solid Mfg HP60's, 5.38's, ARB's, PSC full hydro, 14" coilovers, ASD roof and doors, armored everywhere sitting on 40" Iroks.
Jim Shanks is offline
Replacing my crack exhaust manifold mightydog78 TJ Wrangler Technical Forum 7 08-29-2009 07:35 AM
Replacing the Exhaust Manifold on 92YJ mongowo YJ Wrangler Technical Forum 2 01-10-2009 04:52 PM
Replacing exhaust manifold. Anything else I should do at the same time? VanTheMan YJ Wrangler Technical Forum 4 03-26-2007 08:35 AM
Replacing exhaust manifold tonight, does the instake come off as well? scutter9 TJ Wrangler Technical Forum 3 04-10-2006 12:28 PM
replacing exhaust manifold, need tips rick95 YJ Wrangler Technical Forum 4 06-24-2005 10:46 AM
