replacing exhaust donuts - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > replacing exhaust donuts
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!Poison Spyder Brawler MID Front Bumper for JK
Unread 08-20-2011, 02:46 AM   #1
BobA
I noticed my exhaust is loose where the pipe connects to the exhaust manifold. Figure I might as well replace the 2 donut gaskets while i'm messing with it. Are there any special tools needed to do this or tips to make for a easy job? thanks.
01 TJ Sahara
6cyl. 5spd, D30 Aussie/D44 LSD,4.56 gears, RC2.5" lift, RC1.25" body lift, 33's
77 DJ5
Soon to be streetrod
BobA is offline   Reply With Quote
Unread 08-20-2011, 05:41 AM   #2
Piratejonh
Piratejonh's Avatar
Lots of PB blaster on the bolts.
Jeep took another piece of my finger today...
Piratejonh is offline   Reply With Quote
Unread 08-20-2011, 09:24 AM   #3
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
I don't think your 2001 has those gaskets?...
Knuckelhead is offline   Reply With Quote
Unread 08-20-2011, 10:15 AM   #4
JPNinPA
Once these come loose they will be loosening every 1000 to 5K miles.
Get a set of stage 8 locking bolts or some other bolt/nut combination that will not loosen until you need it.
"Never look down on anyone unless your helping them up"- Jesse Jackson
JPNinPA is offline   Reply With Quote
Unread 08-21-2011, 02:23 PM   #5
BobA
The napa store shows it having them,it would need something in there to create a seal I'd think.
01 TJ Sahara
77 DJ5
Unread 08-21-2011, 02:28 PM   #6
BobA
Thanks for the tip,I'll look into them.
01 TJ Sahara
77 DJ5
Unread 08-21-2011, 04:12 PM   #7
Knuckelhead
AFSOC Retired
You have a tapered exhaust flange fitting, no gasket.
From the FSM:
4. Exhaust pipe leaking at manifold
flange.
4. Tighten/replace flange attaching
nuts/bolts.
No gasket...
Unread 08-22-2011, 08:29 PM   #8
BobA
From the FSM:
flange.
nuts/bolts.
No gasket...
Hmmm.......Seems odd. Thanks guess I'll just crank them tight and see what happen's.
01 TJ Sahara
77 DJ5
Unread 08-22-2011, 08:32 PM   #9
Knuckelhead
AFSOC Retired
At least you don't have the more crackable pre 2000 setup...
Unread 08-23-2011, 07:29 AM   #10
geiman
They showed the same for my 98 4 cylinder and insisted I buy one when getting a new exhaust manifold/gasket. I had them take the manifold out of the box and look at the collector with the tapered flange, at which point the guy tried to fit the donut on saying it was tapered to make it easier to slip on the gasket. I just watched and smiled until he was ready to admit I was right. You can't trust what you hear from the guys working the counter at the parts store.
geiman is online now   Reply With Quote
Unread 08-23-2011, 08:08 AM   #11
chris142
Useless fact: The tapered connection is called a "buick Ball". Buick first used that way of sealing an exhaust back in the 40's.
When we bought our Muffler pipe bender my boss sent me to a class for a whole week on working the bender. I think the Buick Ball is all I remember from the class.
chris142 is offline   Reply With Quote
Unread 08-23-2011, 08:09 AM   #12
geiman
Lol, nice; I'll be sure to remember that, gotta love the useless trivia you pick up from the strangest places.
