Replacing Door hinge pin, not whole hinge - JeepForum.com
post #1 of 10 Old 09-17-2008, 03:32 PM Thread Starter
athos76
Is there a way to replace just the hinge pins on the full steel doors? I noticed that the lower hinge on my passenger door is missing the nut and threads that stick out the bottom of the hinge. I removed the top nut to see if I could get it out, but since I don't have access to my tools right now, couldn't press it out.
If not, I'll have to drop the money on new hinges, since I won't go doorless where I live.
2006 I6 6-Speed X, 33" Goodyear Duratrac, 8.8.
athos76 is offline
post #2 of 10 Old 09-18-2008, 03:57 AM Thread Starter
athos76
Bump to the top. I guess I'm going to have to buy new hinges
athos76 is offline
post #3 of 10 Old 09-18-2008, 07:36 AM
89XJClay
Im sure its possible, by either driving out the pin or drill it out, then installing a new pin, welding it in if necessary.
My question is why? and for two reasons.
1) If one pin still has the nut on it, then no problem there.
2) I drive around with no nuts on the pins at all. Once you shut/lock your door, the door isnt going anywhere, at least not super easily.
89XJClay is offline
post #4 of 10 Old 09-18-2008, 11:46 AM Thread Starter
athos76
I know the door isn't going to go anywhere by itself. It just seems like someone tried to take it off and it broke recently. The dealership had someone come in a month ago missing both doors on their jeep. Someone popped the lock and lifted them off. I just want to make sure their secure. With the area I live in, I wouldn't put it past them to try.
athos76 is offline
post #5 of 10 Old 09-18-2008, 11:48 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
The pins themselves aren't sold separately. I would just install a hinge pin lock on the top hinge only (since the bottom hinge pin is partially missing) like Quadratec sells if you're worried about door theft.
Jerry Bransford is offline
post #6 of 10 Old 06-14-2010, 07:58 PM
mecheng10
You may find that the bushings in the body half of the hinge are worn when you replace the pin. They can be replaced with new custom bushings. Magnitude | Products
-Brian
mecheng10 is offline
post #7 of 10 Old 06-14-2010, 09:44 PM
2jhanna
How about drilling and tapping a hole into the bottom of the existing pin (should be plenty of meat there) and then put a allen headed cap screw or a dreaded torx screw up from the bottom.
Take the door off and turn it over, file the bottom of the pin flat, center punch, drill press or hand drill. dosen't have to be prefect.
jhanna
denton county, tx
2jhanna is offline
post #8 of 10 Old 06-14-2010, 10:13 PM
KKiowaTJ
Mine have been broke for years. Like jerry said, You want the pin you have to buy the whole set-up. I looked into it years ago. Never did anything about it as mentioned, When its shut its as hard as its going to get. If they want it they will get the doors anyway. There is away around a locking device before the lock itself hits the market. Good luck
MOPAR!
KKiowaTJ is offline
post #9 of 10 Old 06-14-2010, 10:17 PM
lumpster
lumpster's Avatar
-Brian
those are pretty expensive for what they are
lumpster is offline
post #10 of 10 Old 10-27-2013, 06:22 PM
HarryTJ
I just bought new hinge pins from Napa didn't come with bushings now just need to know if the old pins on my full doors just bang out or are the one piece with the hinge?
HarryTJ is offline
Replacing door hinge pins? is it possible? Kevinstravels Wrangler General Discussion 0 07-05-2009 05:18 PM
Lower door hinge on windshield hinge bracket for mirror Deacon TJ Wrangler Technical Forum 22 07-03-2009 02:11 AM
New TJ Owner - Replacing Door hinge straps? kellisjeep TJ Wrangler Technical Forum 11 05-06-2008 01:00 PM
Door Hinge Nuts Buried Into The Hinge - HELP!! WindyCityGuy TJ Wrangler Technical Forum 15 05-06-2008 08:39 AM
BoltDoor Hinge & windshield Hinge Screws mascmatt TJ Wrangler Technical Forum 11 03-15-2008 07:08 PM
