Replacing d35 Rear Axle Bearings - JeepForum.com
post #1 of 3 Old 08-04-2010, 10:41 AM Thread Starter
ForumKing
One of these upcoming weekends Iíll be replacing my d35 rear axle bearings. I havenít had to do any work on a rear axle before and was wondering if anyone had a diagram or a how to write up for this job. I searched the other posts, but the ones Iíve found had directions to the d44 axle or a quick explanation of what to do. Iím in the visual learners group, so pics/diagrams would be great!
ForumKing is offline
post #2 of 3 Old 08-30-2010, 02:33 PM
oren77
Looking for this as well
oren77 is offline
post #3 of 3 Old 08-30-2010, 03:31 PM
wushaw
Rockin jeep
wushaw's Avatar
Here is a visual of how to remove the axle shaft to get you started. D-35 Axle Shaft Removal
wushaw is offline
d35 , dana 35 , axle , bearing , replace , replacing
what do i torque the backer plate to? (rear axle bearings) 03rubiconMG TJ Wrangler Technical Forum 3 05-18-2010 05:20 PM
Am I ruined? Replacing rear axle seals on Dana 44 Sahara jeffpas TJ Wrangler Technical Forum 0 05-08-2010 03:56 PM
Replacing rear axle seal with a detroit bama27 TJ Wrangler Technical Forum 9 03-21-2009 10:46 AM
Rear bearings work with Alloy axle shaft? Paul DK TJ Wrangler Technical Forum 0 10-09-2006 01:26 PM
tips on replacing rear wheel bearings pasowicz95yj YJ Wrangler Technical Forum 13 03-24-2004 03:55 PM
