Replacing cooling fan suggestions - JeepForum.com
post #1 of 32 Old 08-06-2012, 09:28 AM Thread Starter
shanedougherty
Hey everyone,
It's time to replace my fan clutch, but while I have the fan shroud and fan out I was thinking of upgrading the fan. I still have OEM, which is nice and heavy, but works great.
Looking to upgrade to aluminum possibly. I don't want to go to electric.
Any suggestions on good brands or where I can get a decent fan that will help lighten the Jeep's load.
Thanks for all the help.
shanedougherty is offline
post #2 of 32 Old 08-06-2012, 09:42 AM
Jeepsr4me
Jeepsr4me is offline
post #3 of 32 Old 08-06-2012, 09:44 AM
biffgnar
biffgnar's Avatar
Results on that have been mixed. Personally, I tried it and went back to stock.
biffgnar is offline
post #4 of 32 Old 08-06-2012, 09:46 AM
VT_Rubi
Stock
VT_Rubi is offline
post #5 of 32 Old 08-06-2012, 10:12 AM
Jeepsr4me
Why did you go back? I had that post saved as a just in case deal.
post #6 of 32 Old 08-06-2012, 10:23 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
x2. tried it, went back to stock. i documented my experience in that thread.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #7 of 32 Old 08-06-2012, 09:47 PM
Bills03tj
1992 XJ Cherokee
I tried it too and went back to stock. It caused mine to overheat on the trail.
Bills03tj is offline
post #8 of 32 Old 08-06-2012, 10:14 PM
Necko2529
Necko2529's Avatar
I run completely stock cooling system with religious maintenance and I've never overheated. Summer temps around here easily go into 115į+ F.
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline
post #9 of 32 Old 08-06-2012, 10:40 PM Thread Starter
shanedougherty
Thanks for all the info. After more research, looks like stock is the way to go. Looks like I'll just go with replacing the fan clutch.
post #10 of 32 Old 08-07-2012, 06:50 AM
wage
On replacing the fan clutch, is OEM best way to go? Or does the HD format work better?
wage is offline
post #11 of 32 Old 08-07-2012, 06:59 AM
Unlimited04
OEM type. the HD/severe duty versions lock up and create too much resistance on the water pump, causing the belts to slip and squeal (which burns/glazes/ruins the belt).
Useful Write-Ups:
Funny:
post #12 of 32 Old 08-07-2012, 12:42 PM
DanZ51
I haven't any such issue with my fan clutch, I've been running the 2791. Here's the Hayden fan clutch catalog. Yes the 2771 is the normal Heavy Duty model for my TJ, 2791 is a Severe Duty version that according to their specs will fit
http://www.haydenauto.com/upload/Hay...fan-clutch.pdf
"I will always be an American Soldier"
DanZ51 is offline
post #13 of 32 Old 08-07-2012, 12:45 PM
Unlimited04
Have you seen sustained 3000+rpm driving under load? I ran the 2791 for a week. It squealed like a stuffed pig above 3000rpms and burned up a brand new serpentine belt.
I've got a 2771 on now, and it squeals too, but not as bad. It's doesn't start slipping until around 3500+ rpms.
Useful Write-Ups:
Funny:
post #14 of 32 Old 08-07-2012, 04:20 PM
Best4x4
The only setup I had squeal was the Torq Flo Severe Duty for the Ford Explorer with the 9 blade fan. The Hayden model with the 9 blade fan didn't squeal at all. I sold my Rubicon with that setup on it and I had good results with it on that Jeep. I now have an LJ and I would install it again, but it's cheaper just to get a new Hayden clutch and re-use the OEM fan blade.
05 Electric Lime Green LJ with a 4spd Auto, 2.5inch Suspension Lift, OME Shocks, OME Steering Stabilizer, 32inch BFG M/T's on 17inch Moab's using Spidertrax Spacers, UCF Aluminum TC Skid, Novak Cable Shifter, Brown Dog MML, Rokmen 1/2 BL, Banks CAI, Diehard Platinum Marine Battery, JW Speaker 8700 LED Head Lights, Safari Nets, G.E.A.R Overhead Console/G.E.A.R Tailgate Storage, Rugged Ridge XHD Front Bumper, Warn Gas Tank Skid, Mopar Rock Crawler Rear Bumper, Warn XD9000i Winch with Warn Wireless Remote, and a Uniden 880 CB Radio
Best4x4 is offline
post #15 of 32 Old 08-07-2012, 09:30 PM
CrankyGypsy
Originally Posted by shanedougherty View Post
Hey everyone,
since i've been considering electric, why not?
2004 Rubicon
2005 Grand Cherokee Limited HEMI (fully optioned)
CrankyGypsy is offline
aluminum , fan , mod , tj
Soft top needs replacing...suggestions on new one? Steph2472 TJ Wrangler Technical Forum 1 04-02-2011 11:14 PM
Replacing the cooling system. Grill off or on? JakeAW TJ Wrangler Technical Forum 6 04-08-2010 12:11 AM
Replacing gears in my 8.8 and D30 any suggestions? Lancsta YJ Wrangler Technical Forum 16 09-07-2009 10:04 PM
Replacing Soft Top...Any Suggestions merkaba TJ Wrangler Technical Forum 8 10-10-2007 08:26 AM
replacing soft top/ need suggestions paul olllllllo TJ Wrangler Technical Forum 2 04-14-2004 11:11 PM
