Replacing caliper, I think I effed up bad.... - Page 2 - JeepForum.com
 5Likes
post #16 of 26 Old 06-19-2017, 11:10 AM
TJnBC
^^^^ he got ya there ...
The threads are NOT in the caliper...they are in the knuckle.
2006 LJR...the madness begins again
TJnBC is offline
post #17 of 26 Old 06-19-2017, 11:10 AM
NotURMailman
NotURMailman's Avatar
The stripped hole is in the knuckle, not the caliper.
A new caliper won't fix anything.
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #18 of 26 Old 06-19-2017, 01:08 PM
biffgnar
biffgnar's Avatar
Originally Posted by Trevlaw View Post
How does a new caliper solve the OP's issue, maybe go ask you friend at the Jeep plant...
Thanks Dodger for sharing your infinite knowledge with us.
Romney in 2020!
biffgnar is offline
post #19 of 26 Old 06-19-2017, 01:11 PM
Trevlaw
Im glad I didn't stop reading after he said new caliper, then I wouldn't have known what sound advice he was giving, especially that C clamp portion
Trevlaw is offline
post #20 of 26 Old 06-19-2017, 01:13 PM
biffgnar
biffgnar's Avatar
If it were directed toward anyone else and I saw it, I'd say he would have been close to a vacation with that last post, but I have a thick skin and generally wait till it gets really ugly if directed toward me before I do anything about it.
Romney in 2020!
biffgnar is offline
post #21 of 26 Old 06-19-2017, 02:05 PM
Trevlaw
Thick skin is a must on here and this forum isn't even that bad. Maybe we'll get lucky and wranglerforum will get a new member...
Dodger60 likes this.
Trevlaw is offline
post #22 of 26 Old 06-19-2017, 02:18 PM
Jeepsr4me
No TJ calipers use SAE bolts to hold them to the knuckle. They are all metric 8mm which is very nearly the same size as 5/16. I'll verify this morning but I don't believe the hole in the guide sleeve has that much slop.
I meant to add that VICE VERSA deal on the bolt.. If its one then switch to another.. And yes there is more than enough slop in the caliper pin hole.. As I had plenty of mix and match bolts in those calipers... Right or wrong, it will get you home... Long as the pin allows the caliper to slide it would be fine.. As for the measuring contest going on, I went to have it enlarged and doc said any more and it be a foot...........:g rin2:
Jeepsr4me is offline
post #23 of 26 Old 06-19-2017, 02:53 PM
pcoplin
pcoplin's Avatar
How do you know when someone is an engineer? Don't worry, they'll tell you.
pcoplin is offline
post #24 of 26 Old 06-19-2017, 02:57 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Originally Posted by Dodger60 View Post
I'm the blind one eh?
LOL...old doesn't always mean obsolete..nor am I closed minded..
I am not steering anyone to anything except a quick acceptable temporary fix to get the OP to work safely.
I myself would use a new caliper if I had stripped this..have I ever been so unlucky or inept as to have done this? No.. apparently you have and I have never suggested that your solution was not the best method.. simply that it was not the only method and it was by far the slowest method so do us all a favor and find a C-section use it to clamp your lips together and then listen with both ears to everything said..
The OP had limited time to effect this repair..he can't wait for that suggested repair kit.. and I personally would choose a helicoil over Loctite.. that is all I have said..
You on the other hand keep berating my knowledge of mechanical engineering without knowing how I make my living.. I am a mechanical designer and work directly with mechanical and structural engineers. A personal friend of mine is an engineer at the Jeep plant in Toledo.. I have been doing repairs for decades and like I said old methods may work when needed. Several designs and projects I have been involved with used helicoils in through holes (thru holes actually) and were certified structurally sound. The issue with helicoils in thru holes as I understand it is for holes frequently used to unbolt and rebolt this is not the case.
Without looking at this specific caliper I cannot be certain as I have worked on too many, but on this one I suspect the hole is a thru hole but only partially threaded meaning the thread itself does have a shoulder that works as a 'bottom' of sorts.. again I am not looking at the caliper so I am not certain but that is a common configuration.
Please do NOT denigrate a poster for offering sound advice based solely on your personal opinion or experience as your personal understanding may be smaller than you believe!
If that sounded condescending...well that was my intent. Have a good day...
Sent from my Nexus 5 using Tapatalk
Before you get too wound up, it helps to know what we're dealing with. The bolt never actually touches the caliper. It goes through a guide sleeve that uses the dust boot as a bushing and the sleeve floats back and forth in a hole in each end of the caliper. The threaded hole is actually in the steering knuckle and most folks strip it due to inadvertently believing that the bolts see braking forces and they don't. They are simply there to keep the caliper in place while the pad ends and cast sliders on the steering knuckle take all of the braking forces.
You are thinking of the GM style mounting that has a pin with threads just under the Allen Head and that screws into part of the caliper. The two methods have very little in common except they are both used on calipers.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #25 of 26 Old 06-19-2017, 03:44 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
The hole in the guide sleeve is 21/64ths. That is just 1/64" bigger than 5/16's so I don't know what bolt you're going to mix and match in there without some drilling. I'm using 5/16" since it practically interchanges size wise with the correct 8mm bolt.
I am Savvy
mrblaine is offline
post #26 of 26 Old 06-19-2017, 04:13 PM
Dodger60
Point made.. frustrates me when someone keeps poking at detail I was not making... Moderator or not it would be good to read more carefully..thick skin? I generally have it but lost it there..my apologies...
Dodger60 is offline
