Replacing axles - Page 3 - JeepForum.com
post #31 of 35 Old 09-12-2010, 08:47 AM Thread Starter
djcrab
Originally Posted by Boundless View Post
I don't want to push you budget higher, but have you thought of lockers? Now would be a great time.
And thanks for your service come back safe!
I have given lockers a thought. My thing is that this is my DD so with that a automatic locker in the front would be ok i think which I have given an aussie a thought for that. But as for the rear I would def need a selectable which is more than I want to spend atm for that. I don't really wheel that hard. Not really into the rocks or anything just mostly wooded trails and some mud holes here and there. So what are your guys opinions on an aussie or another automatic locker for a DD??
Thank you for thanking me for my service lol I'm active AF deployed to very comfortable/safe spot relatively speaking anyway. Still away from my kids and wife but that's the worst part. I'm really thankful to be so fortunate especially whenever I know some people personally in the army who are not in such comforts as I am. My <3 & prayers go out to them for their safe return.
djcrab is offline
post #32 of 35 Old 11-20-2010, 09:14 AM Thread Starter
djcrab
Rather than starting a new thread I figured I would bump my old one. Here's a quick recap for those who do not want to read the previous posts. I have an 04, 4 banger, 5spd on 35s which I am going to swap the D44 from an 01 into and regear to 4.88s.
Here is the gear set I was thinking about getting-->Superior Gears for TJ 4.88 Dana 30 / 44 with Master Install Kits
Would 4.88s be too much. Should I get 4.56s? I commute about 15 miles to work every morning and this is my DD. I want to be able to keep up with traffic at least up to 75 if I can.
Also a automatic locker up front would be fine right? I was thinking about getting an aussie. Opinions/recommendations
Thanks for the input!
Jake
djcrab is offline
post #33 of 35 Old 11-20-2010, 09:31 AM
little_Jeep
Jake
The Aussie should be invisible for the most part in 2wd. You will hear some ratcheting noise on slow sharp turns, like into a parking spot, but nothing you won't soon ignore until a passenger points it out.
I have a 98 with the 4.0L,, I went with 4:56 gears, but I wish I had gone to 4:88. However, your transmission is different than mine and the 2.5L changes stuff as well so you would be better servered if others advise on the gears.
little_Jeep is offline
post #34 of 35 Old 11-21-2010, 11:21 AM Thread Starter
djcrab
Thanks for reinforcing my aussie decision little jeep.
Anyone have a 2.4/5, 5spd, with 4.88s on 33s/35s? Looking for some opinions as to how you like it. Anyone? Thanks.
djcrab is offline
post #35 of 35 Old 11-21-2010, 01:31 PM
breckboarder55
You should at least go with 4.88s with a 5spd and a 2.5L. An Aussie in the front should be pretty unnoticeable while in 2wd.
Thank you for your service.
To Veterans past and present, thank you for your service!
99 Jeep Wrangler-Just another TJ on 33"s
55 Dodge Royal Lancer- Resto Project
87 Mazda RX-7 Turbo II-Built.
87 Mazda RX-7 SE-Burn Victim
01 Honda S2000DD
breckboarder55 is offline
axle , axle replace , tj
replacing YJ rear axles JohnFM3 YJ Wrangler Technical Forum 20 03-08-2010 03:23 PM
Dodge axles VS Ford Axles???? Allen52105 YJ Wrangler Technical Forum 7 08-07-2009 01:23 PM
94 axles to 91 Axles Brake issue???? lawson1273 YJ Wrangler Technical Forum 1 12-13-2008 10:10 AM
New JK Axles/Mopar Performance Axles Badcbr TJ Wrangler Technical Forum 8 08-21-2007 04:36 PM
Superior axles vs. Alloy axles BusyDoinNothing TJ Wrangler Technical Forum 21 06-30-2007 12:40 AM
