Replacing axles - JeepForum.com
post #1 of 35 Old 07-02-2010, 07:21 PM Thread Starter
djcrab
Replacing axles
Well it seems like i've found a decent deal on a set of axles. I found a 30/44 for $500. My plan is to have my wife take them to the shop to get re-geared for my 35s so that when i get back from my deployment I can just bolt them in. The axles are from a 01 TJ and mine is a 04. They should be straight bolt ons correct? Since I'm sure the pumpkin is a different size would i need to get a different driveshaft?
djcrab is offline
post #2 of 35 Old 07-02-2010, 07:22 PM
Jay12
They should bolt right in.
Jay12 is offline
post #3 of 35 Old 07-02-2010, 07:33 PM
TJDaveX
Motorized toy collector
TJDaveX's Avatar
Yes and no. They should bolt right in, but with no spring lift (according to your profile) your driveshaft may be too short. The D44 is 1" longer. You would not be able to tell until you bottom the rear suspension out, and jam your slip yoke into your TC case. Best to do it on jackstands before you put the rear springs back in, instead of on a trail. You can have it shortened at a reputable shop.
TJDaveX is offline
post #4 of 35 Old 07-03-2010, 01:39 AM Thread Starter
djcrab
Just thought of something else. The 44 has 3.73 gears in it atm, I plan on going to 4.88, will I need a new carrier? Thanks.
djcrab is offline
post #5 of 35 Old 07-03-2010, 06:59 AM
2003X
I just ordered a HPD30 and Ford 8.8 from East Coast Gear Supply. I got 4.88s put in them. I have not installed the HPD30 yet, but both axles are identical and will bolt right in. The 8.8 lined up better then the D35 did, and I am re-using my stock ds and upper arms with minimal vibes.
Hope it works out for you, you will love 4.88s.
My Build
2003X is offline
post #6 of 35 Old 07-03-2010, 07:05 AM
TJDaveX
TJDaveX's Avatar
Nope.
TJDaveX is offline
post #7 of 35 Old 07-03-2010, 07:16 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Originally Posted by TJDaveX View Post
Nope.
wrong. D44 carrier break is 3.73/3.92. he'll need a new carrier for 4.88s. D30 front will NOT need a new carrier, that carrier break is 3.54/3.73
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #8 of 35 Old 07-03-2010, 07:26 AM
TJDaveX
TJDaveX's Avatar
oops, I was thinking front. I just ordered 4.88's and my current gears are 3.73's. Sorry djcrab....and LJ04
TJDaveX is offline
post #9 of 35 Old 07-03-2010, 07:35 AM
little_Jeep
You know, while you have the axles out, it would be the perfect time to install a lift kit.... you would be killing two birds at same time. Also, since you will need a new rear driveshaft, or to have your current one modified, you might want to got for the SYE and CV shaft also. I hear stories of people having driveshafts modified for cheap. However, my personal experience (using republic Diesel), I can buy a new driveshaft for what it cost to modify one. If your future plans are for a lift & SYE, you may want to give some serious thought to doing it all at the same time as you will end up with a better setup, and probably save some $$$ in the process.
little_Jeep is offline
post #10 of 35 Old 07-03-2010, 08:16 AM Thread Starter
djcrab
That's what the plan is. I'm ordering either the 3.5 or 4.5 SF rubicon express kit w/ SYE combo of 4x4groupbuy. I had the same exact thought..
djcrab is offline
post #11 of 35 Old 07-03-2010, 08:19 AM
never monday
why would you buy a 30 like you already have?
never monday is offline
post #12 of 35 Old 07-03-2010, 08:24 AM Thread Starter
djcrab
dude will only sell as a set. I don't need anything bigger really so I'm ok with that. I'm going to have the wife take both the axles in to the shop for a re-gear. Then when I get back from my deployment swap them in and sell them.
djcrab is offline
post #13 of 35 Old 07-03-2010, 08:30 AM
never monday
the 44 might be worth it if the set price is good. I'd skip the 30 and go find a HP30
post #14 of 35 Old 07-03-2010, 08:31 AM
TJDaveX
TJDaveX's Avatar
You hit the jackpot! I wish my wife would run Jeep parts for me....especially big ones like axles. Since I am already married and can't go to the parts running wife store, is there a place to send mine to have her retrained?
P.S. A big thank-you for your service.
TJDaveX is offline
post #15 of 35 Old 07-03-2010, 08:39 AM Thread Starter
djcrab
I had thought about that when I was going to order an 8.8. I guess I may still do that since it would be a relatively cheap & easy upgrade.
djcrab is offline
axle , axle replace , tj
replacing YJ rear axles JohnFM3 YJ Wrangler Technical Forum 20 03-08-2010 03:23 PM
Dodge axles VS Ford Axles???? Allen52105 YJ Wrangler Technical Forum 7 08-07-2009 01:23 PM
94 axles to 91 Axles Brake issue???? lawson1273 YJ Wrangler Technical Forum 1 12-13-2008 10:10 AM
New JK Axles/Mopar Performance Axles Badcbr TJ Wrangler Technical Forum 8 08-21-2007 04:36 PM
Superior axles vs. Alloy axles BusyDoinNothing TJ Wrangler Technical Forum 21 06-30-2007 12:40 AM
