Replacing axle seal? - JeepForum.com
post #1 of 4 Old 08-03-2010, 04:05 PM Thread Starter
TimV
I have a 2003 Rubicon, and need to replace the driver side rear axle seal for inspection. I have found write-ups for the actual replacement, but nothing that tells me how to remove the axle shaft to do so. Could someone please direct me to something that shows me how to do it? Preferably with pictures. I'm not big on spending a few hundred to get a shop to do it when the seal is rather cheap.
TimV is offline
post #2 of 4 Old 08-03-2010, 04:31 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Here is what you need from Stu Olson's AWESOME site.
D44 Axle Shaft Removal and Overhaul - 1
To remove the shafts, just unbolt the 4 bolts on the retainer plates at the outside end of the axles. (pic from Stu's site as well!)
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 4 Old 08-03-2010, 06:26 PM Thread Starter
TimV
Thanks Max. I had already read that article, but since it made no mention of removal, I figured it would be safer to ask rather than just dive in. If I had tried to figure it out myself, I would have ended up pulling half of the differential apart. I have only worked on C-clip axles before, and I know this is not one.
TimV is offline
post #4 of 4 Old 08-03-2010, 06:39 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
You're welcome!
I just did this same job on a '97 TJ with a Dana 44 rear a few weeks back. It was a snap, especially the retainer ring removal. I used the same method as the write-up on Stu's site, by drilling almost through it & using a chisel to knock it the rest of the way apart.
Max
Mean Max is offline
axle , seal , replace , replacing
Replacing D44 axle shaft wheel bearing/seal: Round 2 thejafe TJ Wrangler Technical Forum 3 04-18-2010 10:12 PM
Replacing rear axle seal because fluid is leaking into brake drum Nate M YJ Wrangler Technical Forum 4 08-11-2009 02:49 PM
Replacing rear axle seal with a detroit bama27 TJ Wrangler Technical Forum 9 03-21-2009 11:46 AM
replacing axle seal Ksellers11 TJ Wrangler Technical Forum 2 11-17-2008 04:14 PM
replacing axle seal... BigWaylon TJ Wrangler Technical Forum 2 05-23-2004 01:59 PM
