Replacement tie rod rubs wheel well - JeepForum.com
View Poll Results: Where do you take your Wrangler for repairs in the SF Bay area?
4 Wheel Parts, Oakland 0 0%
Golden Gate Jeep, San Francisco 0 0%
Jeep specialty/authorized shop 0 0%
Do it yourself-DIY 2 100.00%
Jeep Dealer 0 0%
Non-Jeep specialized shop 0 0%
Voters: 2. You may not vote on this poll
post #1 of 2 Old 05-02-2010, 04:43 PM Thread Starter
marshcan
I recently replaced my tie rods on my 2000 Jeep Wrangler Sport. I purchased the Rugged Ridge Heavy Duty Crossover Steering System. Now, the tie rods rub the edge on the inside of the wheel wells on both front rims. The bar rubs when you turn hard to the left completely, and the actual tie-rod rubs on the driver side when you turn to the right. I have 15 x 30 x 9.5 with factory steel wheels. What would cause this? Is there an adjustment or is it due to the size of the wheels?
marshcan is offline
post #2 of 2 Old 05-02-2010, 04:52 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Pictures please...
Knuckelhead is offline
steering , tie rod , tie rod ends , tie-rods , wheels
Help! Front Driveshaft rubs. DirtDemon TJ Wrangler Technical Forum 7 02-15-2011 09:26 AM
Front Driveshaft rubs StreetBMXer88 YJ Wrangler Technical Forum 3 03-26-2009 04:44 PM
Tire Rubs Frame robjeanie TJ Wrangler Technical Forum 6 01-25-2009 09:29 PM
Fan rubs BOTTOM of shroud. Bad MM? RYANSTULC TJ Wrangler Technical Forum 6 08-24-2008 11:58 AM
Rear disc rubs on wheel Paul DK TJ Wrangler Technical Forum 12 01-14-2007 09:28 PM
