Replacement radiator - Page 7 - JeepForum.com
post #91 of 93 Old 08-05-2013, 09:24 PM
phrankenstein
FWIW, I just installed a Champion 3 row all aluminum radiator in my '04 LJ today. I was having a lot of issues with it over heating with the A/C on while parked or after restarting from a brief shut down. I replaced the water pump (due to a leak), thermostat (always a good idea when changing water pump), upper hose (had a pin hole), and the fan clutch. My original OEM fan clutch was not engaging very well. I tried all the aforementioned items before the radiator swap with no real good results. Finally, I figured the OEM radiator was pretty much on its way out anyway. So far, it's cooled down about 20 degrees with no issue with the A/C or after restart. The Champion radiator is built very well!!! It's a fully welded design, has good mounting points, and top quality supplied hardware. Keep in mind I'm in West Texas where the outside temp was 104*. Not a single issue today! Good Luck!
phrankenstein is offline
post #92 of 93 Old 08-06-2013, 08:04 AM
RowJ
Originally Posted by phrankenstein View Post
FWIW, I just installed a Champion 3 row all aluminum radiator in my '04 LJ today. I was having a lot of issues with it over heating with the A/C on !
Hope it works for you!
I tried an expensive after market radiator for similar problem.....
could not run A/C at idle or on hwy over 50 mph without overheating.
Did not work.
Solution for me was a Mopar factory radiator. Not sure why but they seem to work better than almost any others!
RowJ is offline
post #93 of 93 Old 08-06-2013, 08:17 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
....'04 LJ....I was having a lot of issues with it over heating with the A/C on while parked or after restarting from a brief shut down.
I had the same issues since nearly new. I tried all the normal approaches, but also settled on the radiator not doing it's job adequately. I installed a Drake Off-Road radiator and it has helped immensely.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
