Replacement radiator - Page 4 - JeepForum.com
post #46 of 93 Old 06-18-2013, 02:32 PM
Ironhead
Originally Posted by RowJ View Post
We're talking about cooled down coolant.... from the bottom of the cooling tubes/fins!
I'm starting to feel like we are beating this subject to death!
i've never gauged it, but how cool do you think the return coolant is? i doubt you'd see more than a 30 deg delta, just a guestimation, so we are talking around 180
Ironhead is online now
post #47 of 93 Old 06-18-2013, 02:33 PM
lunchbox704
Originally Posted by biffgnar View Post
Link for OEM radiator for $100?
http://www.craigslist.org/about/sites
Anything else I can do for you?
lunchbox704 is offline
post #48 of 93 Old 06-18-2013, 02:36 PM
biffgnar
biffgnar's Avatar
See prior message about understanding the difference and be honest with yourself about what you bought. A lot of people by joints they call Johnnie joints but they aren't.
biffgnar is offline
post #49 of 93 Old 06-18-2013, 02:37 PM
lunchbox704
Again, I do. Why are you trying to be such an a-hole?
post #50 of 93 Old 06-18-2013, 02:40 PM
biffgnar
biffgnar's Avatar
You are giving BS advice. Telling people they can buy OEM radiators for $100 is completely misleading. Tell you what, I'll buy as many new in box OEM radiators as you can sell me for $125? You should be able to make a killing.
biffgnar is offline
post #51 of 93 Old 06-18-2013, 02:42 PM
lunchbox704
So the fact that I happened to find one for $100 online (which is why I chose to use that instead of an oem style or some other aftermarket radiator) makes my point any less valid?
You get your jollies trying to bully people online? Simply pathetic.
post #52 of 93 Old 06-18-2013, 02:47 PM
biffgnar
biffgnar's Avatar
Just giving actual usable advice to people reading this thread. Telling people to look for OEM radiators for $100 is like telling them to go find the 7 blade TSB fan.
biffgnar is offline
post #53 of 93 Old 06-18-2013, 02:54 PM
lunchbox704
Reading comprehension would do you well. I never said that he should expect to pay $100, I said that I found one for $100 and I did my install for $100?
Now, are you done hijacking this thread with your need to measure your e-*****?
post #54 of 93 Old 06-18-2013, 02:59 PM
J03_TJ
I went with the OEM PART and installed it myself. Spent about $100 and took about an hour. Better than the $500 I was quoted.
PS, mine had an ATF cooling tank but I just ignored that.
Do they have any more for that price? Can you post a link for me, been anxious to get a new one and that is a excellent price for OEM.
Thanks.
J03_TJ is offline
post #55 of 93 Old 06-18-2013, 03:00 PM
biffgnar
biffgnar's Avatar
No, I'm not done and it has nothing to do with my masculinity. If you were a newb reading this thread and read "I replaced with OEM and it cost me $100" with no other qualification what would you do? I'd think I could find OEM for $100 but that ain't happening. People post **** thinking it makes them sound cool and it turns into crap advice. I'm going to call that out all the time.
biffgnar is offline
post #56 of 93 Old 06-18-2013, 03:01 PM
KaiserJeep
I just want to talk Physics for a moment. First of all, there are TWO things to consider when selecting a radiator. These are the metal used in the core and the number of tubes in the core.
1) Aluminum cores are best - that is what MOPAR uses in the OEM radiator, along with plastic end caps. YES it is true that copper conducts heat better than aluminum, but you ABSOLUTELY CANNOT BUY a copper radiator, and that metal is way too weak and would immediately rupture when the system pressurized. The cheap "Copper/Brass" radiators sold by Radiator Barn and other vendors cool WORSE than the OEM, because brass conducts less heat than aluminum, especially after being painted black. (Black paint is pretty much required or the soldered seams will corrode.) If you replace an OEM radiator with a Copper/Brass unit, even one labelled 2-tube or 3-tube, you will lose cooling capacity versus the OEM aluminum core. You may not realize this is a problem until the first hot weather after the radiator change, which could be months later.
Two brands of premium all-aluminum radiators (i.e. no plastic end-caps) are Griffin and Mishimoto. The Mishimoto 2-tube radiator costs about $350 and offers about 20% more cooling capacity than the OEM 1-tube aluminum/plastic, and offers it at low trail speeds, and they are direct bolt-in. Griffin aftermarket radiators can be configured with various numbers of tubes in the core, and frequently require that you trim sheet metal and use a Griffin fan shroud and/or electric fan, but offer up to 50% or more cooling capacity than the OEM radiator, and are reccomended for up to 5.0L 360-hp blown or turbo stroker Jeep motors.
Premium Griffin radiators are $500 and up, as much as $900 with dual fans and shroud and billet caps. But you can order anything including a unit that will cool a hotrod V-8 engine in a Jeep.
2) The number of tubes in the core is a trade-off and Jeep originally shipped 2-tube OEM radiators in TJs, but switched to 1-tube cores in the later TJ model years. More tubes is better at trail speeds, but at highway speed, more air bypasses the Jeep grille. Fewer tubes does not cool as well at trail speeds, but offers less drag which increases gas mileage slightly and cools better at highway speeds or high altitudes, by allowing more airflow through the front grille. Select the number of tubes according to your needs.
Gary
1967 Kaiser Commando
2001 Grand Cherokee WJ
2003 Wrangler Rubicon TJ
KaiserJeep is offline
post #57 of 93 Old 06-18-2013, 03:04 PM
lunchbox704
Thanks.
No, it was a guy that wrecked his jeep before he had a chance to install it.
post #58 of 93 Old 06-18-2013, 03:07 PM
lunchbox704
Well, perhaps instead of attempting to insult my intelligence by suggesting that I didn't know what I was talking about, you should have asked for clarification first. But you didn't do that. You decided to make an assumption which was completely incorrect.
Good job!
post #59 of 93 Old 06-18-2013, 03:34 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
But I'm also curious to see if cooling fin area on an auto radiator is same as on a manual radiator.
If both are OEM radiators, they are the same. IIRC
Originally Posted by Ironhead View Post
even if its an auto, if your ATF fluid is hotter than your coolant, you have other issues
Nope, that's one of the reasons why the automatic transmission fluid is plumbed through the lower radiator tank.
IIRC it can be closer to 60 degrees.
Did you mean "2 or 3 row"?...
Knuckelhead is offline
post #60 of 93 Old 06-18-2013, 03:41 PM
Ironhead
isnt that backwards, as heat rises, why would you want the hotter liquid at the bottom.
naturally it doesnt make a difference at speed, but while wheeling
