Replacement Manifold - JeepForum.com
post #1 of 4 Old 03-17-2012, 09:37 AM Thread Starter
Rick_Fury
I need to replace my cracked exhaust manifold. This is my second replacement (original cracked, then Borla header cracked), so I would like a good quality unit and a good vendor to buy from. Any recommendations? I am going to go with one with the flex tubes on the ends. Quadrajet sells these for $250, and I have found what appears to be the same one from various Ebay vendors for $100. I am of the mindset that you get what you pay for, but is this the case here?
I would also like to get all new bolts and hardware. What size are the bolts, and where can I find these?
Thanks!
Rick_Fury is offline
post #2 of 4 Old 03-17-2012, 02:42 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
So long as the eBay header looks like this with the two steel expansion bellows (aka flex joints) that stop the cracking, you should be fine.
Jerry Bransford is offline
post #3 of 4 Old 03-17-2012, 03:56 PM
99TJSahara
I used the cheapest ebay manifold with flex joints on my old sahara, and never had any problems, but I bought my own gasket.
-Joey
04 Grand Cherokee Overland
-sold
99TJSahara is offline
post #4 of 4 Old 03-17-2012, 05:08 PM
TheBoogieman
Disturbed
TheBoogieman's Avatar
$70 ebay cheapo with expansion joints and gasket worked great for me.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
TheBoogieman is offline
Manifold Replacement adub2006 TJ Wrangler Technical Forum 8 04-10-2010 02:19 PM
Best replacement 2.5L Exh Manifold? Shawn w TJ Wrangler Technical Forum 8 09-19-2008 06:19 PM
manifold replacement ?? mrbigglesworth TJ Wrangler Technical Forum 1 03-10-2006 11:45 PM
2.5l manifold replacement BuffaloYJ YJ Wrangler Technical Forum 5 05-29-2004 10:38 AM
TJ manifold replacement cspann TJ Wrangler Technical Forum 7 10-29-2003 02:41 PM
