Replacement of 98 Wrangler Sport (W/ A/C) Serpentine Belt - JeepForum.com
post #1 of 15 Old 08-29-2008, 04:22 AM Thread Starter
yawnocmot
I'm going to try to replace my serpentine belt this weekend, and would appreciate guidance.
I've not owned the Jeep long, but the belt has alot of small cracks, and I suspect it's original (Jeep has 59K miles).
After looking at the configuration, I thought the approach would be;
1) loosen the belt tensioner pulley using the long 'adjustment' bolt, which is on a 45 degree angle on the right side facing the Jeep.
2) Replace the Serpentine Belt.
3) Tighten the 'adjustment bolt. with the same number of revolutions , but in the opposite direction.
I don't know whether loosening is clockwise, or counter-clockwise.
Is it this straightforward?
Thanks fpr the help.
TC
yawnocmot is offline
post #2 of 15 Old 08-29-2008, 06:13 AM
ltmitch
The rule is "lefty loosey righty tighty".In other words counter clockwise to loosen and clockwise to tighten.
HTH
Neil
ltmitch is offline
post #3 of 15 Old 08-29-2008, 07:16 AM
lanesmat
Remember that you have to loosen the tension pulley bolt before you attempt to adjust the tension adjustment bolt. The pulley bolt locks down your adjustment on the tension bolt.
lanesmat is offline
post #4 of 15 Old 08-29-2008, 07:23 AM
patricknolan
Draw a picture of the belt while its still on. Youd be suprised how long it takes to figure out where the new one will go without something to look off of.
patricknolan is offline
post #5 of 15 Old 08-29-2008, 09:00 AM
n5xl
TC
Check your private mail, I sent you some info you'll need.
You might consider getting one of these from your local NAPA
http://www.napaonline.com/MasterPage...+Tension+Gauge
With the info I sent you and the gauge, you are golden.
N5XL
n5xl is offline
post #6 of 15 Old 08-29-2008, 09:13 AM
TJeeper
TJeeper's Avatar
Don't forget to retighten the belt after 100 miles.
I use the 90 degree method. The belt should be tight enough that it can be twisted 90 degrees at the longest straight line.
Patrick
TJeeper is offline
post #7 of 15 Old 08-29-2008, 10:45 AM
jeepwrnglr92
2015 JK Wrangler
Anyone have the routing diagram for a 4banger? I have to replace mine this weekend. Yes I have AC
If not Ill get the digital camera out
2015 Jeep Wrangler JKU "Tank" Sport S
2002 Avalanche: To many mods to list
jeepwrnglr92 is offline
post #8 of 15 Old 08-29-2008, 06:07 PM
n5xl
Check your mail. Compare the diagram to what you have to be sure.
n5xl is offline
post #9 of 15 Old 09-09-2008, 09:11 PM
gasman42
Does the tensioner work the same on a 4.0 on a 2002. Never done this before but that's the fun of a Jeep
gasman42 is offline
post #10 of 15 Old 09-09-2008, 09:19 PM
Stu Olson
Stu Olson's Avatar
I don't believe so....(going from memory).....I think the tensioner is near the alternator....it is one of the spring loaded types. I believe a 3/8" or 1/2" square ratchet end can be used to gain mechanical leverage to move it to get slack in the belt.
Or I could be completely wrong and this is for yet a newer TJ.
Stu Olson
ARB Locked & Loaded
Stu Olson is offline
post #11 of 15 Old 09-10-2008, 07:46 AM
gasman42
Thanks, seems the hardest part is remembering the path of the belt
gasman42 is offline
post #12 of 15 Old 09-10-2008, 07:56 AM
jeepwrnglr92
2015 JK Wrangler
post #13 of 15 Old 09-10-2008, 09:12 AM
BarneyJEEP
i always just remember smooth pulleys to the smooth side of belt, ribbed to ribbed...it should only fit one way.
BarneyJEEP is offline
post #14 of 15 Old 09-10-2008, 09:20 AM
cowboyway
If it's a 4.0 L, this link will help.
http://www.getahelmet.com/jeeps/maint/belt/
cowboyway is offline
post #15 of 15 Old 09-10-2008, 12:27 PM
gasman42
thanks for the help !
gasman42 is offline
90 YJ Serpentine Belt Replacement amg61 YJ Wrangler Technical Forum 7 06-15-2009 05:27 PM
serpentine belt replacement Obcean2 YJ Wrangler Technical Forum 17 01-04-2008 01:34 PM
Serpentine Belt Replacement Write-up? daren71 TJ Wrangler Technical Forum 6 12-27-2006 01:27 PM
Serpentine Belt Replacement 2.5 liter rupert TJ Wrangler Technical Forum 3 11-30-2004 07:26 PM
serpentine belt replacement fbombs YJ Wrangler Technical Forum 4 07-01-2003 01:48 PM
