Replaced u-joint, now I get better gas mileage? - JeepForum.com
post #1 of 5 Old 06-29-2010, 07:38 PM Thread Starter
khill8469
two weeks ago i replaced my axle u-joints and both wheel bearings and now im getting better gas mileage. Does this make sense or is it just a coincidence?
khill8469 is offline
post #2 of 5 Old 06-29-2010, 11:36 PM
troys96xj
Makes total sense.You have proper operating units now.There no drag from the bad bearings.Everything is smooth.
troys96xj is offline
post #3 of 5 Old 06-29-2010, 11:42 PM
Bigmanboog
the new U joints and Bearings will lessen friction which. the less friction, less engine strain, equals better fuel economy. I wouldn't be surprised if your gas milage increased by a few MPG but you have to rate Jeeps in FPG( fun per gallon) verses MPG because the FPG is always higher in a Jeep
If you cant stand behind our troops do us a favor and stand in front of them
Bigmanboog is offline
post #4 of 5 Old 06-30-2010, 03:27 PM
BlueFlame
BlueFlame's Avatar
It is amazing how much energy is consumed with vibrations.
When I first got my jeep the suspension wasn't set up well, and I had rear driveshaft vibes.
Adjusting the control arms to eliminate the vibration 'felt' like it freed up a bunch of power, and made a difference in gas mileage too.
BlueFlame is offline
post #5 of 5 Old 06-30-2010, 09:05 PM Thread Starter
khill8469
i did it all for safty andy to get rid of a squeak that was dring me up the wall. but if i knew i would get so much better gas mileage i would of done it a long time ago.
u-joint , u joint , mpg , gas mileage , tj , wrangler
Replaced U-Joint seems siezed tommanns YJ Wrangler Technical Forum 8 04-09-2010 10:44 PM
Replaced blower, replaced resistor... still fan doesn't work Levin2000 TJ Wrangler Technical Forum 1 12-19-2009 04:47 PM
Replaced Right Front U-Joint, thanks to Forum BamaYJ91 YJ Wrangler Technical Forum 1 12-31-2008 06:30 PM
Replaced U-joint..now clicking.. TJSahara98 TJ Wrangler Technical Forum 7 07-26-2008 08:57 AM
Replaced Speedo Gear - mileage is tracked, speedometer doesn't move koheed TJ Wrangler Technical Forum 10 05-13-2007 03:18 PM
