replaced O2 sensor, error code still there!
| Truck-Lite's New LED Headlamp Series | 4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed | Ruffstuff Axle Simple Swap Kit! |
#1 | |
So i replaced my upstream oxygen sensor 3 days ago only to get the code back the day after. The code i get is 21.
If everything was done right should the code go away on it's own, or does it have to be manually cleared, if so how? Thank you ![]()
#2 |
it will go away on its own after so many complete cycles that it doesnt detect the code, but it can take awhile. have the code cleared (or buy a cheap code reader then can clear codes) and see if it ever comes back
Click here --> - Buy popular magazines at discounted price, help my daughter for school DIY jeep highline guide -> click here DIY highline guide Save up to 40% off at advance auto parts by buying online, pick up at store free! |
#3 | |
Nanners...MMMM..Toasty
Disconnect the battery and let it sit for a few. Then reconnect the battery. It should reset that code. if it comes back on then there is still a problem somewhere.
<--- I got a big Dancin Nanner Jeepiki.com - Jeep Encyclopedia Quote:
N7GTJ View my Paddock Pool construction nightmare at http://www.paddockpoolsucks.com/ |
#4 | |
I went off roading the next day and mid-way through my trail the "check engine" lamp came on. I cycled the on-off and got the damn 21 code back Anyone know what i should do next? I guess there must be something else causing this problem? FYI, the codes i get are 12, 21 then 55. So the jeep isn't telling me much ... suggestions? ![]() |
#5 |
Pull the connector apart and have a look if all the pins are lined up properly. I replaced mine years ago and one of the pins got pushed inside the connector stopping it connecting.
"Giving English to an American is like giving sex to a child. He knows it's important but he doesn't know what to do with it." Adam Cooper (19th century) Rockauto 5% discount code can be found here... http://www.markviii.org/LOD2/products_services.htm Online factory service manuals can be viewed at http://www.jeep4x4center.com/knowledge-base/index.htm#service Parts list PDFs available from http://www.berrysprinter.com/jeepparts.php |
#6 |
I did that. All connections seem solid and the pins aren't rusted or anything like that ...
#7 |
You may have to check the harness wiring from the Powertrain Control Module (PCM) all the way out to the sensor connector using a multi-meter.
Anyway you can get to a code reader to get the OBD-II code value? This will give more information. Autozone, if local to you, will extract the code for free.
4.0L TJ 5.7L CTS 3.7L KJ |
#8 | |
#9 |
Dogman, I have read that from another site but that description refers to multiple sensors. "21" is a Chrysler internal code. OBD-II codes are more specific and may narrow the problem down.
#10 | |
I will have to give that a try and report back with more info. However, can you elaborate more on checking the PCM connections with the multi meter. What exactly am i checking for? Just that the connections are solid, or for a specific resistance in ohms or what? Thanks so much ![]() |
#11 | ||
A generic OBD-II code reader that worked on your father's ODB-II Ford will work on any OBD-II vehicle including your Jeep. I would start with extracting the Powertrain diagnostic trouble codes P0XXX (0 = generic) or P1XXX (1 = manufacturer specific). Trouble codes involving O2 sensors can be tricky. Many assume that the senor is bad but the problem maybe a vacuum leak or a stuck/clogged/leaking fuel injector. Getting this "P" code would be a great start. Quote:
Upstream O2 Sensor (from 1998 Service Manual, assuming '97 is the same) Orange/Dark Green: (+)12V Sensor Heater from 20A Fuse 21 in the engine compartment fuse relay box Black: (-)Heater circuit ground Black/Dark Green: Sensor Signal to pin A24 on PCM Brown/Yellow: Sensor return to pin A4 on PCM Downstream O2 Sensor (from 1998 Service Manual, assuming '97 is the same) Orange/Dark Green: (+)12V Sensor Heater from 20A Fuse 21 in the engine compartment fuse relay box Black: (-)Heater circuit ground Tan/White: Sensor Signal to pin A25 on PCM Brown/Yellow: Sensor return to pin A4 on PCM 1998MY TJ PCM Connector C2 ![]() 1998MY TJ Downstream O2 Sensor Connector: (Upstream O2 Sensor similar, gray) ![]() Good Luck.
4.0L TJ 5.7L CTS 3.7L KJ Last edited by Slithering_Joe; 12-22-2007 at 03:50 PM.. |
#12 |
Just a couple more questions regarding this interesting problem....
My internet search has not been very conclusive on whether the "Bank 1 sensor 2" is the oxygen sensor found near the Catalytic converter or near the exhaust manifold. The reason i ask is that the Jeep tells me the error code is "21" which means "upstream O2 sensor" when i do the ON-OFF sequence. But when i connect the OBD Reader it tells me P0138 which sounds like the downstream sensor .... and i doubt both would be shot at the same time, seems very unlikely. Also ... the Catalytic converter has been replaced several months ago, could that in itself cause a code? Slithering Joe, thanks for that detailed how-to. I will do that as soon as the rain dies down outside. Thanks very much ![]() |
#13 |
according to all data it is a downstream o2 sensor shorted to voltage. the possible causes is gives are;shoeted output circuit, bad sensor, pcm, connector, and open circuit. hope this helps!
#14 | ||||
Sensor 1 is before the catalytic converter. Sensor 2 is after the catalytic converter. Quote:
You really can't assume that both sensors are shot because you haven't proved that the upstream sensor was bad! And from the sound of it a code 21 deals with the downstream sensor since you extracted a P0138 using the OBD-II interface. Therefore, the upstream sensor is unrelated. Understand? My guess, since this is hard to do over the internet, there may be an open circuit somewhere in the sensor signal wiring or the O2 sensor connector to harness connector connection. If that is OK, then the sensor is bad. (Worst case scenario after you have exhausted every possible diagnostic test, the PCM is bad. This is rarely the case.) Here is some good reading on O2 sensor operation: http://www.aa1car.com/library/o2sensor.htm Quote:
Additional reading if you like: http://www.aa1car.com/library/p0420_dtc.htm Quote:
4.0L TJ 5.7L CTS 3.7L KJ Last edited by Slithering_Joe; 12-22-2007 at 11:09 PM.. |
#15 | |
Does it have aftermarket exhaust? Sometimes headers wont let the O2 sensor heat up to get an accurate reading. I am not sure if yours is using a heated O2 sensor or not.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
