Replaced ignition now nothing happens - JeepForum.com
post #1 of 1 Old 01-21-2010, 05:53 PM Thread Starter
aklsufan
I have 99 TJ 4.0 auto tranny. I replaced the ignition switch because the radio/blinkers stopped working with this one from JC Whittney Item Number: 1JA 280225. Now the brake light and passenger air bag off light are lit with the ignition switch in the off position. When the ignition switch is turned to start nothing happens. The jeep has been sitting up for about 2 months before I finally installed the switch and I verifed that I have good battery voltage and during the 2 months I have been starting the jeep. Any ideas on where to start.
aklsufan is offline
Epic Ignition Battle (replaced everything but the ignition switch!) thechadwick YJ Wrangler Technical Forum 10 08-27-2009 11:02 PM
94 YJ 4.0L ignition problems, I've replaced everything I can think of ltjblalo YJ Wrangler Technical Forum 10 04-21-2009 07:40 AM
No spark..replaced crankshaft sensor, ignition coil, distributor(rotor and cap) amsgwp YJ Wrangler Technical Forum 4 03-08-2009 09:16 PM
Replaced stereo and that annoying ignition buzzer isnt working? Roach YJ Wrangler Technical Forum 7 12-07-2005 01:58 PM
HELP!!! Replaced Ignition Module, won't run! bidnizman YJ Wrangler Technical Forum 5 10-12-2004 07:24 PM
