Replaced exhaust manifold, when started revs to max rpm - JeepForum.com
post #1 of 4 Old 11-20-2010, 12:08 AM Thread Starter
dmp362
I replaced my exhaust manifold. After putting everything back, when I went to start it the engines rpms rev extremely high and will keep going if I let it.
I have checked for vacuum leaks there were none, replaced IAC and MAP sensor, which didn't make a difference. I have read over other threads with similar problems, but they only had responses involving vacuum leaks.
And now I am running out of ideas.
dmp362 is offline
post #2 of 4 Old 11-20-2010, 12:19 AM
Heap-O-Jeep
you have an intake leak somewhere. most likely you dont have the intake sealed against the head properly. which is a vacuum leak. double check to see if your sealed against the head or see if you possibly cracked the manifold when installing it. i changed my exhaust manifold and i had a tough time getting the manifold back on the dowel pins. pull the intake off again get a file and LIGHTLY scuff out the dowel holes on the manifold. basically pull the manifold off and double check everything you did that should reveal the issue causing the WOT condition.
WHY DO YOU NEED TO KNOW WHERE YOU ARE GOING?
Heap-O-Jeep is offline
post #3 of 4 Old 11-21-2010, 06:26 PM
mnstretch
1976 CJ7
same thing happend to a friend when he rebuilt his engine. the dowel pins didnt seat all the way. he said the power steering pump was hard to line up with the intake not seated on the head.
mnstretch is offline
post #4 of 4 Old 11-21-2010, 08:52 PM
epeck87
vaccume leak between the intake manifold and the cylinder head. spray some throttle body cleaner around the area of the gasket and if you have a leak the engine will suck in the vapor and engine speed will increase at a noticeable rate. try touquing down your intake manifold bolts again.
Associates Degree in automotive technology
A1-A8 ASE MASTER CERTIFIED TOYOTA MECHANIC
epeck87 is offline
idle issue , idle problems , idle too high , idles rough
Manifold install, motor revs WOT on start JeepMud02 TJ Wrangler Technical Forum 18 07-30-2008 07:47 PM
Engine revs up after exhaust manifold install... Gav'spurplez TJ Wrangler Technical Forum 36 06-23-2008 08:55 PM
How to tell (visually) if exhaust manifold was replaced el guapo TJ Wrangler Technical Forum 7 03-16-2007 11:33 AM
For those who have replaced the exhaust manifold...? usmctopgun TJ Wrangler Technical Forum 3 03-02-2007 09:47 AM
Replaced Exhaust Manifold, now it bucks w/Check Engine light HotDogWater YJ Wrangler Technical Forum 15 09-18-2006 11:42 AM
