Replaced clutch, now possible interlock problem. Help! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Replaced clutch, now possible interlock problem. Help!
ZONE 4.25" combo lift for TJ available at Rockridge4wJeep Wrangler Bushwacker Flat Fender Flare Sale at BaselinRIGID LED Light Blowout Sale - All Sizes, All Series, all
Unread Yesterday, 11:49 PM   #1
slick2570
Alright, so the clutch went out on my jeep ('03 Rubicon) so i ended up replacing pretty much everything i could while i had it apart. (Pressure plate, TO bearing, pilot bearing, clutch fork and flywheel) I probably didn't need to replace the flywheel, it wasn't in terrible shape, but my jeep has 150k miles so i figured it wouldn't hurt. And the clutch fork was trashed because when my clutch went out i may have forced the clutch pedal down to try and encourage it into gear so i could limp the last 2 miles home. It didn't work though, obviously. Instead it created a lot of grinding, which turned out to be the clutch fork against the clutch housing.
So fast forward to after i replaced everything: I went to start the Jeep and make sure everything was good, and all i got was a single, loud click from the starter.
My battery is less than 3 months old and reading a solid 13ish volts (even when trying to start the jeep). The terminals and cable connectors are clean. I had the starter bench tested at an auto shop, it tested fine. And lastly, i bypassed the starter cable with another battery cable i had laying around and got the same result. SO, its looking like its the clutch interlock sensor, or whatever that thing is..
My main concern is that the clutch pedal seems REALLY light after replacing the clutch. Like, almost non-existent. As if the slave cylinder rod isn't pushing against the clutch fork or something. But i was very careful to make sure it was seated properly in the fork. So i don't know what it could be. Replacing the interlock wouldn't give me any added resistance or anything, right? Isn't it just a sensor to make sure the clutch is engaged?
Does the clutch interlock monitor stuff within the tranny itself, or just the actual clutch pedal? Like, if the clutch weren't properly engaging within the transmission itself, would the interlock system pick up on that somehow?
I've looked up as many threads about the interlock that i could, but none really answered all of my questions. So if you guys could offer up some opinions/advice/help, it would really be appreciated! Thanks
-Eric
2003 TJ Rubicon - stock for now
1999 WJ - Gone
slick2570 is offline   Reply With Quote Quick reply to this message
Unread Today, 03:20 AM   #2
PA_LJ
You can bypass the clutch interlock by inserting a 10a fuse in the #20 slot...
Try that...
Did you reinstall all of your electrical connectors and the CPS on the bellhousing?
Maybe ur clutch master/slave blew when your clutch let go?
My TJ Build
PA_LJ is online now   Reply With Quote Quick reply to this message
Unread Today, 04:34 AM   #3
GringoLoco
What got me is that the starter clicked loudly when the key was turned. That wouldn't happen if it was just the interlock. Pull your battery cables and wire brush the connections, it might have a connection issue keeping it from getting the amps it needs.
YELLOW Jeep Club Member #5606
13 mpg - edit: 12 mpg
No hi-lift on the hood (yet)
Odd noises
Still can't get it to take off from a treadmill....
GringoLoco is offline   Reply With Quote Quick reply to this message
Unread Today, 02:15 PM   #4
slick2570
The battery terminals and cables are super clean. I will double check all the sensors and plugs around the bell housing, hopefully that's all it is. I'll also try adding the fuse to see if bypassing it works. What are the symptoms of a broken slave cylinder and how do I check to see if it's bad for sure? Can I just remove it from the bell housing and push the clutch pedal in to make sure the piston is moving, or what? Thanks for the help! -Eric
1999 WJ - Gone
Unread Today, 03:37 PM   #5
MJBinNM
Starter gear not meshing properly with new fly wheel? Did you remove the starter to replace the flywheel? It may have hit the gear and locked up.
You must have grown up in the no winners no losers generation where everyone gets a participation trophy and a pat on the butt for just showing up with their clothes on right side out.
MJBinNM is offline   Reply With Quote Quick reply to this message
Unread Today, 03:42 PM   #6
PA_LJ
A bad clutch master or slave will have no pressure when you depressed the clutch pedal...
I would not cycle the clutch pedal with the slave pulled from the bell housing as you are likely to damage the slave if its not already broken...the master/slave is a closed system that rarely need tampering with but when the slave is out of the bell housing depressing the clutch pedal forces the slave arm forward under pressure. With nothing to retain the slave arm the assembly can fall apart. I have never tire this and have been was against it. So take it for what it is.
Start with the easy and cheap...the interlock fuse is pennies vs a new master/slave assembly and will tell you volumes. If it doesnt start after bypass the clutch then something else is wrong (CPS). If it starts after bypass then id bet your clutch master/slave is bad and is not engaging the interlock.
My TJ Build
Unread Today, 07:58 PM   #7
slick2570
I did replace the flywheel, but the starter isn't engaging at all. Its not like it is stuck or anything, it doesn't even try to spin, all it does is click. The bad clutch master or slave sounds like it matches all of the symptoms i'm having. I'll start trying to narrow that down. Thanks for the help, i really appreciate it!
1999 WJ - Gone
Unread Today, 08:14 PM   #8
jkp
A bad clutch master or slave will not cause your Jeep not to start.
If you bypass the clutch safety switch under the dash on the pedal, or put the fuse in to bypass it, your Jeep will start up in gear and start moving without using the clutch at all. That's why there is a clutch override fuse. In 4LO you can start and stop the Jeep simply by turning the key on and off with it in gear.
My '06 Rubicon automatically bypasses the clutch switch when you put it in 4LO, but I don't think it worked that way on the '03s.
'92 Islander
'06 Rubicon
jkp is offline   Reply With Quote Quick reply to this message
