Replaced Brake Booster - now brake lights stay on - JeepForum.com
post #1 of 5 Old 07-29-2005, 05:55 PM Thread Starter
Viking
I finally tracked down my soft brakes and wandering idle to a brake booster leak. I replaced the booster and the master cylinder, trying to adjust the booster rod as best I could. The idle is smooth as could be now, the brakes are strong, but the brake lights now stay on. I've pulled the switch and it looks fine, it just looks like the brake pedal is staying down about 1/4" at the pedal, so it just doesn't quite press the switch far enough to turn off the lights.
Any ideas? Could this be related to the adjustable booster rod, and if it is, should I make the rod longer or shorter?? There doesn't seem to be any adjustment to the brake light switch (other than a little dab of epoxy on the top of the plunger to make it a little longer - my last option).
Thanks in advance!
Viking
'97 TJ, 4.0l, Auto, Mostly stock except:
ORF Sport Cage
31" Tires, 3.73 Gears
Rock Hard rear bar mounted low behind
rear seat for urban defense of my kids
Viking is offline
post #2 of 5 Old 07-29-2005, 09:27 PM
rhinoss
Did you replace the booster with a stock vacuum booster?
You mention the adjustable booster rod, I'm sure that would be it. It's been a while since I've been under the dash, although I think you'll need to lengthen the adustment if you're looking to bring the pedal closer to you.
The brake switch is a very touchy, if it's barely off position at all, your brake lights will either be on all the time or never on at all.
97 TJ Sport|I6 5spd Hard top|D44 Rear|
|4.5" RE Superflex|RE 3.5 springs|Adj front/rear track bars|RE Gen 2 Disco's|
|MORE 1" MM|RE 1" TC drop|Jeeperman Trail Skidz|Warn rear / Bobbed stock front bumper|33x10 BFG AT's|
|Kenwood KDC-MP5028|iPod interface|Excelon 4x6|Excelon 6"|
|Stuffed Chicken riding shotgun|
rhinoss is offline
post #3 of 5 Old 07-29-2005, 10:01 PM
Stu Olson
Stu Olson's Avatar
The brake switch has an adjustable plunger on it so that it can be adjusted for just this problem. If I remember correctly, the write-up on my hydroboost describes how this is done.
Stu Olson
ARB Locked & Loaded
Stu Olson is offline
post #4 of 5 Old 08-01-2005, 12:25 PM
Vancopbs
Get a pair of wire cutters. Push the brake pedal down, using the wire cutters pull the brake light switch (the tab) all the way out. Let go of the brake pedal, it's self adjusting.
Van
Vanco Power Brake Supply
9738 Atlantic Ave
South Gate, Ca 90280
800-256-6295
323-563-1588
Vancopbs is offline
post #5 of 5 Old 04-11-2017, 06:46 PM
ggullifordjr
had this exact same problem happen today and thanks to @Van copsbs fixed it in 2 minutes. Thank you sir for the 12 year old advice.
ggullifordjr is offline
Replaced turn signal switch now no brake lights? brinoff YJ Wrangler Technical Forum 5 08-06-2009 06:48 PM
After brake booster install, brake lights are on??? HoustonRenegade YJ Wrangler Technical Forum 6 05-17-2009 07:49 PM
bad brake booster? JOKER4INK YJ Wrangler Technical Forum 7 03-27-2006 08:48 PM
Brake Booster ??? offroadjeep1 TJ Wrangler Technical Forum 1 05-22-2003 10:19 PM
Has anybody replaced the foot parking brake with hand brake jake100 YJ Wrangler Technical Forum 0 06-11-2002 10:19 PM
