Replace your TJ Condenser W/O Removing the Radiator - JeepForum.com
post #1 of 2 Old 07-11-2012, 11:18 PM Thread Starter
pioneerduster
My friend and I proved it and we found some things on the way.
1. Bleed the Freon from the System
2. Remove the inlet/outlet lines from condenser
3. Next, remove the condenser with 10mm wrench - Note: there are some TOUGH ones to get to - Remember there are TWO that must be removed from underneath the radiator.
4. Carefully push the Radiator lines back against the motor and the condenser should slide out.
You might notice that the rubber washers are destroyed - SO - we found a great replacement - Check out part number 665-2079 at Napa Auto Parts. They are a 1/4" 20 Rubber Well Nut! These things are sweet as they collapse when they are tightened.
Anyhow - all said and done - never doing it before - we did the job in 2-hours and the system has held for more than a week in SUPER HOT temperatures. So - Good news is that we do NOT need to replace the compressor - at least not yet - So just the Condenser CAN be all you may need to get blowing Cold Air again. I have photos (hit me up if interested) as I can't post them in the Newbee forum yet.
Good Luck and YOU CAN DO IT!!!!
pioneerduster is offline
post #2 of 2 Old 08-07-2012, 05:47 PM
JeepsAre4Speed
1994 XJ Cherokee
Sweet I was wondering about that. I recently took out my compressor and cut the lines out(ac worked great but I dont like extra junk I dont use) and the condessor is next. Maybe I'll put some rat wire in place just so the radiator still has some protection.
JeepsAre4Speed is offline
a/c , condenser , tj
Replace a Radiator hokymn TJ Wrangler Technical Forum 11 01-03-2012 08:51 PM
radiator leak. get the radiator fixed or replace? LiveAndLearn TJ Wrangler Technical Forum 32 11-24-2011 10:06 AM
Spectra radiator and condenser; any good? MattJeep TJ Wrangler Technical Forum 3 07-24-2011 05:19 PM
removing the radiator fan langston.4 TJ Wrangler Technical Forum 8 12-22-2009 08:29 PM
Fix or Replace Radiator Doc_Vegas TJ Wrangler Technical Forum 5 02-10-2007 08:12 PM
