Replace stock CA bushings or buy new arms? - JeepForum.com
post #1 of 3 Old 07-11-2010, 06:31 PM Thread Starter
bobthetj03
Installed my trackbar over the weekend with a JKS adjustable. Been fighting a DW condition for a while now and I wanted to get my front axle centered anyways so decided to start with the TB. While I was under there I checked the normal stuff. took a pry bar and checked ball joints, all good. Checked tie rod ends, good. Put it in the air and check wheel bearings, tight. Took a pry bar to the lower CA's. Holy Cr**! Lots of slop! Uppers were not quite as bad. Lowers definetely need replaced. My question is...Is it worth the effort to replace the stock CA bushings, or would I be better off getting some Currie's?
I also had the front tires balanced, and still not totally sure the shop took the time to balance them perfectly, so I think my tires may still have a factor. After installing the new TB, my DW turned into a shimmy at 50mph. No DW but definetely a shimmy in the steering wheel at 50. I think if I replace the lower CA's and find a shop that can balance the front tires to 0 I think I may beat this thing.
Bob's boring build:
White Jeep club member #2003
bobthetj03 is offline
post #2 of 3 Old 07-11-2010, 08:00 PM
Fropleyqk
Fropleyqk's Avatar
It all depends on your budget. If youre tight for money, take a look in the for sale section. People are always trying to get rid of stock parts. You should be able to pick up a used set of front lowers for like $20. If youre looking to upgrade, absolutely go with Currie or another brand of choice. I always look to upgrade when a stock part takes a poop. But I make sure I have the budget for it.
Fropleyqk is offline
post #3 of 3 Old 07-11-2010, 10:13 PM Thread Starter
bobthetj03
I hear ya! Unfortunately, the budget is tight, But I'm looking at the big picture. You know what it's like! You buy an upgrade, and you can't wait to buy the next upgrade! I think I'm getting close to solving my DW problem, and I guess I just wanted to hear someone say, " you know what to do" ! By the time I pull the factory CA's, buy new bushings, press them out, press new ones in and still have no adjustability to adjust caster! Think I know what to do.
Bob's boring build:
Control arm , bushings , replace , movement , slop
How does one replace bushings? GERD JK Wrangler Technical Forum 4 11-17-2009 04:56 PM
Replace RE Bushings in 4.5 SF or buy Currie Short Arms ISurvivedNMU TJ Wrangler Technical Forum 17 10-08-2009 02:29 PM
Replace Shackles or Bushings? Caligeaux YJ Wrangler Technical Forum 12 07-18-2009 10:04 PM
Buying greasable bushings, should I replace stock shackles? CaptAmerica219 YJ Wrangler Technical Forum 12 01-09-2008 05:21 PM
conrol arm bushings replace ShadowJeep TJ Wrangler Technical Forum 0 05-21-2004 08:41 PM
