Replace the steering wheel - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Replace the steering wheel
ROCKRIDGE 4WD Supports our Service Members! Military DiscCurrie Currectlync Steering Upgrade Kits and Currie Anti-RMemorial Day Weekend Sale Starts Friday-Tuesday 10% off +
Unread 03-07-2010, 03:23 PM   #1
dougiefresh131
Has anyone ever tried to do this? I did a quick search on google and on here and couldn't find much. Can it be done relatively easily?
dougiefresh131 is offline   Reply With Quote
Unread 03-07-2010, 05:07 PM   #2
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Disconnect the battery and wait 15 minutes to make the airbags safe. Remove some trim screws and airbag screws, remove the steering wheel nut and use a steering wheel puller. Takes about 10 minutes once the airbags are safe.
Progressive Liberalism: Bringing you new ideas so wonderful, they have to include mandatory participation ......
Originally Posted by Ronald W. Reagan
Government is not the solution to our problem; Government is the problem.
CJ7-Tim is offline   Reply With Quote
Unread 03-07-2010, 05:35 PM   #3
dougiefresh131
so if i found, say a jk steering wheel, could i pull off the one I have now and the jk one would screw right in?
Unread 03-07-2010, 05:40 PM   #4
CJ7-Tim
CJ7-Tim's Avatar
XJ and TJ share the same steering wheel.
You probably cannot make a JK steering wheel "fit".
replace , replacement , steering , switch , wheel
