Replace odd ball 1999 A/C Compressor with 1991-1998 compressor??? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Replace odd ball 1999 A/C Compressor with 1991-1998 compressor???
End of Summer Sale, 20% OFF!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRough Country Jeep Suspension Deals at Rockridge 4WD!
Unread 09-01-2011, 03:17 PM   #1
negreac
I was wondering if it was possible to replace the 99 a/c compressor with a '91-'98 "sanden" model with little to no modification. It looks like the mounting bracket is similar if not the same. If that is the case all I would need is 1997 or 1998 a/c high and low pressure lines right? Unless of course they changed the condenser and drier pipe locations in 1999 as well. FYI the only reason I ask is because the Sanden compressor are much cheaper to replace (under half the cost) and they allow for a kilby kit to be installed without hacking into your fender. Here are a few comparison pics:
1999 A/C Compressor
1998 Compressor
1999 Engine Bay
1998 Engine Bay
1999 Jeep Wrangler Sport 4.0L Auto (Under Construction)
negreac is offline   Reply With Quote
Unread 09-01-2011, 07:09 PM   #2
Ej132
Sorry I'm no help but what is a kilby kit?
Ej132 is offline   Reply With Quote
Unread 09-01-2011, 07:32 PM   #3
chris142
If you used the Sanden compressor and the manifold assembly from a 98 I don't see why it wont work. An AC shop can make hoses and whatever is needed to make it work.
We do it all the time. Doc's blocks has all kinds of hose ends and AC connection stuff.
http://www.docsblocks.com/
chris142 is offline   Reply With Quote
Unread 09-05-2011, 12:06 AM   #4
negreac
The Kilby On-Board air kit.
Unread 07-11-2013, 05:34 PM   #5
jesse18
Did this ever work out?
1999 TJ Sport w/ 3" lift and 33"s.
[url]http://www.jeepforum.com/forum/f22/jts-tj-996480/[/url]
jesse18 is offline   Reply With Quote
