Replace exhaust manifold studs with bolts?? - JeepForum.com
post #1 of 6 Old 07-12-2009, 10:17 AM Thread Starter
JeSimmers
JeSimmers's Avatar
What bolts would you reccommend to use in place of studs??
Red Jeep Club Member #454
JeSimmers is offline
post #2 of 6 Old 07-12-2009, 10:56 AM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Why did you want to replace with bolts?You only have a couple of studs at each end right?
GOLENJEEPTJ is offline
post #3 of 6 Old 07-12-2009, 11:39 AM
flexsaharatj
I re used the same bolts after I did my install of a new one..
flexsaharatj is offline
post #4 of 6 Old 07-12-2009, 12:06 PM
GOLENJEEPTJ
I think he is speaking of the 2 studs,one at each end of exhaust port on cyls. #1 and 6?
post #5 of 6 Old 07-12-2009, 12:11 PM
weems
The alignment pins or dowels? Why do you need to replace these?
98 TJ Sport
9.5k Warn TI
ARB Rear Locker
Aussie Front Locker
4.56 Gears
Currie 44/Dana 30 chrome moly
weems is offline
post #6 of 6 Old 07-12-2009, 01:14 PM Thread Starter
JeSimmers
JeSimmers's Avatar
The studs are broken off on my current head, I am replacing the head completely. As of now I have no studs or bolts, So plan to use just bolts and nix the stud idea completely. My question was...what grade/type of bolt should I use to install my manifold onto the new head?
Exhaust Manifold Flange Bolts....or Studs?? buckz YJ Wrangler Technical Forum 7 11-15-2009 09:57 AM
How to replace exhaust manifold BChamberlin TJ Wrangler Technical Forum 9 07-23-2007 10:34 AM
how difficult to replace exhaust manifold? Bot YJ Wrangler Technical Forum 7 10-01-2005 12:50 AM
2.5 Exhaust Manifold Studs or Bolts AlexMedic TJ Wrangler Technical Forum 1 04-28-2004 11:03 AM
