-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   replace 2003 skid plate with <2003 (http://www.jeepforum.com/forum/f9/replace-2003-skid-plate-2003-a-399429/)
frankske_ 04-08-2007 05:52 PM
Since the 2003 skid plate is (a lot) lower than the older models, I was thinking about replacing it with pre 2003 skid plate. Is it just a matter of swapping both or am i missing something? Will I need to replace the transmission mount as well?
Bill_Dunnigan 04-08-2007 05:56 PM
where'd you hear this rumor?
they all have the same ground clearance
otisdog 04-08-2007 06:31 PM
The holes are a different pattern.
also the older ones are standard bolts while 03 - up are metric.
jim
frankske_ 04-08-2007 06:32 PM
It's pretty obvious just looking at it, man that thing hangs low!
I also read about it a couple of times on the forum, like here and here.
otisdog 04-08-2007 06:42 PM
Yes 03 - up are lower. They call them the "shovel"
They did this to accomodate the bigger t-case on the Rubicons that started in 03 and just put them on all TJ's.
Jim
frankske_ 04-08-2007 07:00 PM
I don't mind drilling a couple of holes and getting new bolts :).
Would I need to get a new transmission mount as well or are these the same?
Could I use a YJ plate too ?(easier to find used in Belgium) ...
The time now is 06:01 PM.
