Repainting Bumpers - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Repainting Bumpers
End of Summer Sale, 20% OFF!2007 - 2011 Jeep JK Long Arm Lift KitsIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 04-01-2014, 05:54 PM   #1
confused8
Repainting Bumpers
Hi, So this winter I finally got around to pulling of my front and rear warn rock crawler bumpers. They have some rust and the paint is chipping off. Whats the best option for paint. A local guy quoted me 350 for a media blast and powder coating. Is that too much? Im able to ship them if needed or is there a better way of painting? Im looking for the cheapest most durable method.
confused8 is offline   Reply With Quote
Unread 04-01-2014, 07:25 PM   #2
1CleanTJ
i live in the salt belt just like you.. I had the best luck with prepping the bumpers (scrap loose paint off, sand the rust off etc, wash / clean with solvent) and using brush on bed liner. its very easy to touch up and looks good.
1CleanTJ is offline   Reply With Quote
Unread 04-01-2014, 07:29 PM   #3
Pkauf123456
I wouldn't powder coat them and I can get it done for free. It's expensive for everyone else and scratches almost as easily as paint. Believe it or not, Rustoleum is very good for this. I'd use a wire wheel to clean the rust and loose paint off the bumpers. Then prime them with Rustoleum primer and spay them with satin black. I like satin because it touches up easily when scratched. Gloss requires a full reprint to match nicely. Not a big deal when you consider the price and time. I guess you figured out that I actually use my bumpers. If I didn't rub things, I might consider powder coat.
Pkauf123456 is offline   Reply With Quote
Unread 04-01-2014, 09:43 PM   #4
geroux
I have the same bumpers. They are powdercoated. If you have very deep pockets, re- powdercoat them. I personally would remove as much rust as you can, treat with something like Ospho and paint with some rustoleum. Plan on touching up every fall and spring.
geroux is offline   Reply With Quote
Unread 04-01-2014, 09:52 PM   #5
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Do you have pictures of the rust on your bumpers?...
TSB Information: http://www.automd.com/tsb/jeep_m/wrangler_mm/2000_y/
Knuckelhead is offline   Reply With Quote
