Quantcast Removing transfer case drop... bolt lengths question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Removing transfer case drop... bolt lengths question
Old 04-20-2009, 03:34 PM   #1
turbotwin
Hi,
I have an 05 Rubi. When the PO had the lift installed, the shop put on the included transfer case drop. Since they're totally unnecessary, I'll be taking them off on the next garage day. Will I need to get shorter, factory-length bolts, or can I just remove the spaces and tighten these longer ones down? If I need to go shorter, anyone have an old set lying around, or know the size & length so I can go pick them up?
Thanks,
Todd
2005 Unlimited Rubicon
3.5" RE Superflex
turbotwin is offline   Reply With Quote
Old 04-20-2009, 03:35 PM   #2
klincker
i think youll need the short ones because the long ones arent threaded the entire way.
OIIIIIIIO
99 TJ Sahara, 2.5 RC Lift, 32" BFG Muds.
klincker is offline   Reply With Quote
Old 04-20-2009, 04:11 PM   #3
USCGTWEET
bump for a good question
USCGTWEET is offline   Reply With Quote
Old 04-20-2009, 05:30 PM   #4
V-8unlimited
pretty sure you will need stockers. Another thing to worry about is driveline angle. Does it have a sye kit? I just lifted my buddies YJ, and I did not use the transfer drop, instead I lifted the engine 3/4".
EDIT:: You do have a SYE from factory (sorry didn't fully read the post). However you may need a longer driveshaft. I believe you also have a CV driveshaft from factory. A motor mount lift will help address your driveline angle, or also upper adjustable arms will help.
V-8unlimited is offline   Reply With Quote
Old 04-20-2009, 06:33 PM   #5
billbanshee
rubicons dont have a slip yoke
98 tj sahara
re4.5sf,bfg 33 12.50mt d30arb/d44 detroit 456 gears
bulletproof bumpers/tomken skids/tor roll cage
warn 9000i
billbanshee is offline   Reply With Quote
Old 04-20-2009, 08:34 PM   #6
V-8unlimited
sorry about that, guess I didn't read it very well.
Old 04-20-2009, 08:37 PM   #7
AlTheKillerr
go to home depot and pick up some grade 8 bolts there. thats what i did. just get em an inch shorter
AlTheKillerr is offline   Reply With Quote
Old 04-20-2009, 08:44 PM   #8
tjthorson
tjthorson's Avatar
Originally Posted by turbotwin View Post
Hi,
Thanks,
Todd
As stated - just get some grade 8 from the hardware store. Im not sure where the "totally unnecessary" comes from? Transfer case drops exist for a reason. In the case of your rubicon - you do NOT need a SYE kit as the rubi transfer case has a fixed yoke. however - you may need a CV driveshaft, or a motor mount lift after removing the TC drop....
If you have ANY vibes at all - you will need to address it.... which is usually easily addressed by that "totally unnecessary" TC Drop....
Todd Thorson
2005 Yellow Unlimited Rubicon 4" front springs, Caprice Wagon CC623 (3.5") rear springs, BL, BMML, Rokmen TT, SJ Hydros
Yellow Jeep Club Member #4
http://www.toddsplace.com
tjthorson is offline   Reply With Quote
Glock Forum
