#1 | |
Removing the Transfer Case Drop...
When I bought my Jeep I was told it has a SYE kit installed as well as a different drive shaft. I believe it was a Tom Woods but I could be wrong. The drive shaft does look like a CV type drive shaft.
With that being said, can I remove the T-case drop? I do not have adjustable rear control arms. I will post up pics of what I have installed when I get home. And I will also find out if anyone I know has an angel finder to find the angel of the drive shaft. Thanks!
My daughter just asked me if I can buy a motorcycle when I'm done with my Jeep!! |
#2 |
Demonic Jeep Freak!
Without adjustable control arms,I doubt it.SYE pic.
#3 |
This is a crappy cell phone pic of what I have...
http://http://farm4.static.flickr.com/3456/3864991130_020a0bd34d_b.jpg
#4 | |
Click free: ![]() Congrats, you have a SYE. But your control arm angles suck.
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#5 |
I would get upper rear adjustables first then remove the drop.
You want that angle right. Jim
03 Sport |
#6 |
The Jeep keeps popping out of 4l. Could the Tcase drop be the reason why?
#7 |
the linkage needs adjusted. crawl under there, its easy to do.
#8 |
I was under there last night. I've been searching for what needs to be adjusted and how to adjust it. I want to buy the linkage kit but can't spend the $150 on it right now.
#9 | |
Demonic Jeep Freak!
Teraflex 1900001 - TeraFlex Basic Transfer Case Shift Linkage Kit for 97-02 Jeep® Wrangler TJ - Quadratec |
#10 | |
Transfer Case shift linkage adjustment - JeepForum.com
#11 | |
I also read your post about how to adjust the linkage. Problem is I can't always get my tcase to go all the way in 4l.
#12 | |
Demonic Jeep Freak!
#13 |
Loosen the nut that is on the shifter lever?
#14 |
Demonic Jeep Freak!
#15 | |
That is the one that has the 14mm bolt holding it in place? When I loosened it last night the rod did not move freely.
So I put in in 4l, loosen the bolt to make sure the tcase is in 4l, then tighten it up? Quote:
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
