Quantcast Removing Transfer Case Drop - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Removing Transfer Case Drop
Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.comRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com
Old 09-08-2007, 06:10 PM   #1
alvinl
Today I am pulling out the transfer case so I can install the SYE kit. While I have it apart I am thinking about removing the 1" TC drop. My first question is, do I need to worry about the linkage or anything when I remove this. Right now everything shifts good. It looks like the 4low selector is easily adjusted by loosening a single bolt on the linkeage. If all I have to do is loosen this bolt and readjust the linkeage, that seems easy enough. Is that all I will have to do?
My second question is just how do I push the TC back up. Do I just jack it up in place and reinstall the skid plate?
alvinl is offline   Reply With Quote
Old 09-08-2007, 06:33 PM   #2
Fyrflie
You don't need to drop the transfer case to do the SYE.
I did mine in the jeep.
2000 TJ Sahara
4.0, 5 Speed, D30, D44 w/Detroit Truetrac, 4.56 gears
Rancho Lift, Body Lift, Motor Mount Lift, SYE & 33" tires
Fyrflie is offline   Reply With Quote
Old 09-08-2007, 08:07 PM   #3
alvinl
Hmmm. I have heard a couple people that did it under the Jeep. Do you still have to remove the front drive shaft if you do it under the Jeep?
Old 09-08-2007, 08:15 PM   #4
Fyrflie
If I remember right, I did remove the front drive shaft. It was real simple.
I drove the front of my jeep up onto some vehicle ramps and jacked up the rear and supported with jack stands to get enough clearance under the vehicle to work on the transfer case.
I am 6' 1" and I could actually sit-up under the jeep while working on the transfer case.
Check out www.4x4explor.com for a detailed right-up on this project. That coupled with the instructions from the SYE kit will make it real easy. If you can wrench at all, this should be a fairly easy project.
Hope this helps.
2000 TJ Sahara
Old 09-11-2007, 10:57 PM   #5
alvinl
Well, I got my SYE installed. But I ran into a snag when I went to remove the TC drop. The bolts that were holding the TC skid on are not threaded all the way to the head, they are smooth where the spacer was. DOH! Looks like I will need new bolts. I am looking for a place to buy them locally, but I will probably end up going to a junk yard or ordering them online. The only odd thing about them is the conicle shape under the bolt head so I might be able to find some conicle shaped washers.
But it is that close to being done. It's not even bolted up yet and I already like the looks of the TC back up under the Jeep.
Old 09-11-2007, 11:15 PM   #6
JBWood05TJ
Cut to Fit-Paint to Match
JBWood05TJ's Avatar
I just went to Ace and got bolts that were one inch shorter. I just did my SYE too. I can believe you worked it in with the T/C skid in place. Or did I misread that?
We save dogs: http://www.secondchanceshepherds.org/
JBWood05TJ is offline   Reply With Quote
Old 09-11-2007, 11:25 PM   #7
alvinl
I removed the skid, but I did do the SYE under the Jeep. It was not too bad, but would definitely have been easier out on my workbench. Live and learn. The only problem I had was with the oil pickup. It was a pain keeping it all together while fitting the case back together, but I got it done.
I need to play with my linkeage also. I currently have a drop bracket on the shifter and I am going to pull that off and shove everything back up under the Jeep.
Glock Forum
