Removing T Case Drop? - JeepForum.com
post #1 of 10 Old 07-09-2010, 09:46 AM Thread Starter
ItsaFinRubicon
What do I have to do to take away my T case drop?....
I have a 2004 Jeep Rubicon w/ a rough country 4" X-Series lift kit. W/ adjustable control arms...
Can I just take it off without having any problems?
I heard of people buying bl and mml lifts... does that work?
and if I buy a new cv driveshaft would that work as well?
I''m just trying to get a straight answer on how to get rid of it...
thanks
Mike
|R.C. 4"|PSC|Smittybilt|35" KM1|QTec|R.C.|
Originally Posted by Dtowngoalie View Post
rausch frock rauschhhhhhhhhhhh
Originally Posted by ajamison View Post
trails frock trailssssss!
ItsaFinRubicon is offline
post #2 of 10 Old 07-09-2010, 09:51 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
see the CV driveshaft thread linked in my sig.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #3 of 10 Old 07-09-2010, 09:53 AM
srlbotanical
To remove the T-case drop you will need to install a SYE and CV drive-shaft...
Two Trackers 4WD Club
Wheeling in West Michigan for over 35 years.
HIGHER POWERED!!
srlbotanical is offline
post #4 of 10 Old 07-09-2010, 09:55 AM
R0cket
1930 TJ Wrangler
i have a SYE and CV shaft. and i removed my tcase drop. LOVE IT.
Ian
AME2 USN, Disabled Vet
R0cket is offline
post #5 of 10 Old 07-09-2010, 09:56 AM
superslayer
You could use an MML but you may still need a like a 1/4" belly pan drop. Every jeep is different.
You dont need an SYE for an rubicon, only a double cardan driveshaft.
superslayer is offline
post #6 of 10 Old 07-09-2010, 10:00 AM
srlbotanical
Originally Posted by superslayer View Post
You dont need an SYE for an rubicon...
Good catch, I forgot about the 241 fixed yolk...
HIGHER POWERED!!
post #7 of 10 Old 07-09-2010, 10:03 AM
Unlimited04
yolk? isn't that in eggs?
the NV241OR uses a fixed flange.
Useful Write-Ups:
Funny:
post #8 of 10 Old 07-09-2010, 10:07 AM
kuruma
OP: Thanks for asking this. I want to do the same thing. Been researching like crazy and think I have it figured out but this made it a bit more solid. Here's the next question: Who is going to donate to the make my Jeep better fund so I can do all of this?
kuruma is offline
post #9 of 10 Old 07-09-2010, 02:19 PM
Sgt.Fuzz
Get in line brother.
My build:
Sgt.Fuzz is offline
post #10 of 10 Old 07-09-2010, 04:47 PM
R0cket
1930 TJ Wrangler
haha i didn't even think to look if his was a rubi or not
Ian
R0cket is offline
tj , wrangler , rubicon , transfer case , t-case , t case , drop
Removing transfer case drop after installing SYE & CV D.S.? Matt Graham YJ Wrangler Technical Forum 29 05-19-2011 05:22 PM
Removing the Transfer Case Drop... JeeperFound TJ Wrangler Technical Forum 15 08-28-2009 09:07 AM
NO vibrations after removing x-fer case drop? FLATFENDER54 TJ Wrangler Technical Forum 9 03-31-2008 05:39 PM
Removing Transfer Case Drop alvinl TJ Wrangler Technical Forum 6 09-11-2007 10:25 PM
removing skyjacker T-case drop problem bbjandc TJ Wrangler Technical Forum 6 09-01-2005 04:05 PM
