Removing stripped Torx bolts - JeepForum.com
post #1 of 3 Old 02-17-2006, 11:46 PM Thread Starter
voigtrobert
Seeing all the posts about Torx bolts and our woes with them, I thought I'd post a method of removing stripped ones that I stumbled on by accident after I stripped a couple of mine. But first: after I stripped mine, I tried an Easy Out [not!], as it promptly broke as soon as I tried to turn it. Since I have no personal acquaintance who welds, I went to two shops to have a nut welded on the bolts: one place wanted $50, and the other place was afraid he'd mess up the paint and refused to do it--said try a body shop, and come back to him as a last resort.
So I tried something I had never seen suggested here before. Using a Dremel, I cut a groove near the edge of the Torx at about the 9 o'clock postion. I made the groove big enough to accept a nailset solidly. Then I beat on the nailset with a hammer and after 10 or so sharp raps with the hammer, the Torx started to turn. I got both stripped Torx out by this method. On reflection, I could have used a drill instead of the Dremel to make the hole or groove in which to place the point of the nailset. If you use this method, be sure the groove is deep and big enough so that the nailset does not slip, and be very careful if you're working near any glass.
This was all after trying PB Blaster AND heat with a propane torch to get the darned things out in the first place. Also while using the Easy Out, I used heat from the propane torch. After finally getting them out, I noted some very obvious corrosion on about the top 1/4" of the threads and that was what had frozen them into place.
BobV
'00 Sahara 6-cyl, auto
voigtrobert is offline
post #2 of 3 Old 02-17-2006, 11:53 PM
ThatGuysXJ
THANX
When they say "Don't be That Guy" They're probably talkin about me.
ThatGuysXJ is offline
post #3 of 3 Old 02-18-2006, 12:57 AM
bluehdmc
I've used drills to get them out. Actually had a tailgate hinge bolt that stripped and when I drilled the head off it screwed into the tailgate. I'd recommend a left handed drill for the next time. It's recommended to drill all the way through a broken bolt before using an easy out. This relieves pressure on the threads.
bluehdmc
North NJ
2005 Stone White Rubicon Unlimited
White Jeep Club #53
1999 Harley Road King
2006 BMW R1200RT
bluehdmc is offline
HELP! Stripped torx bolts on window hinge distantdog TJ Wrangler Technical Forum 42 05-11-2011 02:07 PM
Help Please...Stripped Torx bolts in windshield frame. Prryan45 TJ Wrangler Technical Forum 10 09-08-2009 10:04 PM
More stripped torx bolts? Deadhorse TJ Wrangler Technical Forum 3 05-21-2009 07:50 AM
Stripped Torx Bolts! (removal & replacement?) Bethlehem TJ Wrangler Technical Forum 10 11-02-2008 12:49 AM
solution for stripped torx bolts YJ_95 YJ Wrangler Technical Forum 15 05-26-2008 12:16 PM
