Quantcast removing steering stabilizer....HELP!! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > removing steering stabilizer....HELP!!
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!RUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 08-04-2004, 01:36 PM   #1
T odd's J eep
How does the steering stabilizer come out of the hole in the tie rod bar. i got the end out where it connects to the frame but does the other end screw out or should i just be able to hammer it out. both things are stock is the tie rod threaded or not.
thanks
Todd
1997 TJ, Black, 2.5 Low Output, 2in RE BB, Cragar 342s, 32x11.50x15 BFG All Terrains, 4 Hella 500's, Awia headunit and 6 speaker soundbar, CB, Fire Extinguisher, K&N Filter
Black Jeep Club #21
Firefighting Jeep Club Member #69
T odd's J eep is offline   Reply With Quote
Old 08-04-2004, 01:39 PM   #2
Brian4.2
Is a taper fit. A small puller will work. Or put the nut back on,hold a piece of wood between the nut and your hammer on and beat it .
Brian4.2 is offline   Reply With Quote
Old 08-04-2004, 01:46 PM   #3
cspann
I just replaced mine and it was a Biotch to get off. I beat it too hard and flatened the bolt. So then I heated it with a torch, cut the bolt with bolt cutters, then smacked it through with a BFH... Good luck,
1997 Black on Yellow
4.0 Manual
Rubicon Express 3.5" 33 BFG's
Locked up front
ATOZ rockers ([B]the best Ive found[/B])
a litle bit of armor, more to come
Super 35 w\Detroit coming in soon.
and then sum.........
cspann is offline   Reply With Quote
Old 08-04-2004, 01:46 PM   #4
JFiorentino
thanks
Todd
It just so happens that I changed my stock Steering Stabilizer yesterday. I put in a Rancho 5000 stabilizer. I went to Harbor Freight Tools and bought a $6.99 Pitman Arm Puller tool. A few turns of the nut and out popped the stock stabilizer.
By the way, I no longer feel shaking in my steering wheel when I hit bumps in the road. Also when I start and stop, I used to feel the tire lugs shaking my wheel, and that is gone as well.
John
John
"When approaching a four-way stop, the vehicle with the largest tires always has the right of way"
2004 TJ, Auto w/ OD, 4.0L, Off-Road 36x13.5 Super Swamper IROK's on MT Classic II Rims, SYE, CV Driveshaft, 4:56 Gears, ARB Locker, 3.5" RE Superflex, 2" Body Lift, JKS Quicker Disco's, 9,000# Winch, Toys-by-Troy step-sliders, The Source OBA. And lots more....
JFiorentino is offline   Reply With Quote
Old 08-04-2004, 02:16 PM   #5
Jasonoff
Humm... maybe I will upgrade my stabilizer.
[B]2002 TJ Sahara ([color=white]White[/color])[/b]
Light Guards & Flowmaster 40 Series Delta Flow...5spd
[B]2000 Honda S2000 ([color=gray]Silverstone[/color])[/B]
TJ took it's place...
[color=white]White Jeep Club Member #706[/color]
Jasonoff is offline   Reply With Quote
Old 08-04-2004, 02:55 PM   #6
Grimmjpr
Bfh..... :d
Grimmjpr is offline   Reply With Quote
Old 08-04-2004, 03:51 PM   #7
T odd's J eep
thanks guys a 5 lb sledge does wonders to the jeep. does anyone know the torque specs for all of the front end stuff like trac bar and tie rod ends and the stabalizer.
Black Jeep Club #21
Glock Forum
