Removing Outer Door Handles On Full Doors? - JeepForum.com
post #1 of 7 Old 03-09-2006, 08:33 PM Thread Starter
daren71
The powder coating is starting to flake off my outer door handles and I was wondering if anyone has taken theirs off to repaint? They look like a real pain in the arse to get off. Looks like some sort of chinese puzzle on the inside... I'd just hate to start prying things off before I get some advice. It wouldn't be so bad if they weren't starting to rust.
I know I could paint them on the door but the paint is flaking off everywhere and behind and I'd like to have them blasted.
Thanks
daren71 is offline
post #2 of 7 Old 03-09-2006, 08:42 PM
CNY
Caught ridin' dirty
FULL DOOR OUTSIDE RELEASE HANDLE
REMOVAL
(1) Remove the door trim panel.
(2) Position the window in the full upward position.
(3) Remove the grab handle support bracket.
(4) Peel back the waterdam from the door inner panel to access the door latch.
(5) Disconnect from the latch, the inside lock knob to latch rod and, the outside release handle to latch rod (Fig. 1).
(6) Disengage tail of retainer from handle keeper.
(7) Using a long flat blade, tap the handle keepers upward and remove from the door handle (Fig. 2).
(8) Remove the latch release rod from the door handle.
(9) Separate the handle and gasket from the door.
INSTALLATION
(1) Engage the latch release rod to the door handle.
(2) Position the gasket and handle in the door.
(3) Slide the keepers into the door handle from the
top.
(4) Lower the window.
(5) Using a long flat blade, lightly tap the handle
keepers downward to secure the handle. The tail of
the retainer must be positioned on the 2nd or 3rd
step from the bottom on the handle keeper.
(6) Raise the window.
(7) Connect to the latch, the inside lock knob to
latch rod and, the outside release handle to latch rod.
(8) Install the waterdam
(9) Install the grab handle support bracket.
(10) Install the door trim panel.
CNY is offline
post #3 of 7 Old 03-09-2006, 08:43 PM
TJgreg
TJgreg's Avatar
^^^ Might be easier just to tape them off
Semper Fi
TJgreg is offline
post #4 of 7 Old 03-09-2006, 08:52 PM
CNY
Caught ridin' dirty
CNY is offline
post #5 of 7 Old 03-09-2006, 08:55 PM Thread Starter
daren71
Stickers... geeze and I work in a sign shop... i should've thought of that.
Seriously, I wanted to do this right. I've read over those instructions and still a bit confused. The removal instructions didn't say anything about screws, but the very last install note was to install the screws...
daren71 is offline
post #6 of 7 Old 03-09-2006, 09:02 PM
Rocky529
Rocky529's Avatar
Tape it off, it is a PITA to take off the handles. Trust me
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #7 of 7 Old 03-10-2006, 06:28 AM
CNY
Caught ridin' dirty
Originally Posted by daren71
...... I've read over those instructions and still a bit confused. The removal instructions didn't say anything about screws, but the very last install note was to install the screws...
I messed up and put the wrong install instructions.
I have fixed it and added a pic.
CNY is offline
Removing Exterior Door Handles CheapSunglasses YJ Wrangler Technical Forum 19 05-29-2010 10:05 AM
Full Doors - Door Handles jim_bert TJ Wrangler Technical Forum 12 06-30-2009 09:34 AM
Removing door handles? DCGayhart TJ Wrangler Technical Forum 2 04-25-2007 07:49 PM
Door handles -- full doors dlb TJ Wrangler Technical Forum 2 10-21-2006 08:04 PM
Installing outer door handles, full door 2K TJ... BucJeeper TJ Wrangler Technical Forum 4 09-28-2006 07:21 PM
