removing original steering stabilizer
| 1984-2001 Jeep XJ Cherokee Lift Kits 3-4.5" with Full | Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line | Spartan Lockers FREE SHIPPING Excellent Prices |
#1 | |
removing original steering stabilizer on 2000 jeep wrangler
the bolts wont come out i have tried penetrating oil and heat and beating it with a hammer it just wont come out. is it threaded in???? any help will be great the jeep has got to get me to school in the morning.
#2 |
It's tapered, get a bigger hammer
#3 |
ok i just went a bought an air hammer and special tool to beat it out and it still doesn't work any advice?
#4 |
you can try using a pitman arm puller, but a big hammer will do it, try some heat maybe as well.
-my build thread- |
#5 |
a torch and a big ****ing hammer will do the job.
#6 |
pitman arm puller had mine off in a few turns of the wrench.
#7 |
I tried using a 'regular' hammer and couldn't get mine out. I switched to a 3lb hammer and it took two swings.
so +1 on the BFH |
#8 |
JF is my second home.
Heat from a torch, and then a nice 3lb ballpien hammer worked for me, two good hits and flew right out.
Max 2003 Jeep Wrangler Rubicon 4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs. TJ Tech Boot Camp TJ Specs "Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track" |
#9 |
Jerry suggested a good method that worked for me. Found it through search...
#10 |
This is exactly what i hate about internet douchbags! Everybody thinks there a badda$$ and tells the other person to "go search". If you know the answer to something, help a guy out and tell him the damn answer, post a link, something. Just because it took YOU forever to find answers and YOU had to do all the searching, you think other people should suffer with you. ******r!
#11 |
soak it with pb blaster, let it set for 45 minutes to an hour.
try to use the hammer again, it should pop right out. this worked for me. |
#12 |
Another vote for pitman arm puller. PB blaster soak for a few hours and a couple turns of the wrench.
#13 | |
2001 Yellow Sport, I6, Dana 44 3.73 gears, 31x10.5 procomp AT on cragar soft 8s, silverstar headlights, black headlight bezels, raingler full netting system, raingler roll bar handles, EK motorsport maglite holder, Tuffy door lockers, Tuffy glovebox, stepshield door entry guards, 130w Halogen KC Daylighters on windhield mounts, kenwood kvt-819dvd, 5.25" front speaker conversion, door switch defeat, U-Pol Raptor liner, Dynomax Super Turbo Cat-Back Exhaust, Iggee seat covers, SAVVY LED Taillights.
#14 |
Blue On Black
http://www.jeepforum.com/forum/f9/removing-steering-stabilizer-851169/
X2 on the arm puller. This guy didn't use it first and it drove him crazy. lol |
#15 | |
Let me google that for you 1st on the list: Jeep - Rancho Steering Stabilizer Installation 2nd on the list: TJ Steering Stabilizer ^^the two most helpful Jeep tech write-up sites you'll find. ![]()
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
