Removing Gear Shift Knob? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Removing Gear Shift Knob?
Amsteel Blue Synthetic Winch line Free ShippingSteering and more from Ruffstuff!Rough Country Deals at JeepHut.com
Unread 12-29-2005, 10:13 AM   #1
Black Hills TJ
I have a 97 and for the life of me I can't figure out how to get the gear shift knob off. I need to take it off to replace the shift boot retainer ring that broke.
Any help guys?
Thanks in advance.
Mike
Originally Posted by Allenwr
My mouth still has funky taste in it, so I am doin alright.
Originally Posted by ImSuck
damnit i wish i could get bigger quicker
Check out www.blackhillsjeeps.com!
Black Hills TJ is online now   Reply With Quote
Unread 12-29-2005, 10:22 AM   #2
Waddell
Pry out the piece of plastic with the shift pattern on it and you will find a nut holding the knob on. There are a few posts on here that show the pictures. I removed the shift pattern piece and replaced it with a Miller Lite cap.
Waddell is offline   Reply With Quote
Unread 12-29-2005, 12:13 PM   #3
CJM
Mine was super tuff to get off. Although I realisied after getting it off that there is a "hole" to the left of the shift pattern that should grip a screwdriver easier.
'05 Unlimited Rubicon
[COLOR=Navy]Navy Blue[/COLOR], Manual, Dual Tops
285 Destinations w/Spidertrax, Deluxe kit from DPG
[URL=http://i15.photobucket.com/albums/a392/CJM1/Jeep%20Pictures/43377.jpg]Pic of my Rubi.[/URL]
CJM is offline   Reply With Quote
Unread 12-29-2005, 12:37 PM   #4
bcompton
I destroyed mine getting the cap off, but a new knob and cap was pretty cheap at the Jeep dealer, plus I took the opportunity to replace the shift boot too so it all looks new and ready for another 100k miles!
01 Sport, front drum brake & birfield joint conversion, custom '4 Wheel Drive' stickers, neon washer nozzles, chrome type 'r' oil pan bolts, wooden bead seat pads, racing exhaust tip, offroad license plate frame,
lots of misc. stuff (2.5" Skyjacker springs, 1" BL, 1"MML, Custom flat tcase & engine skid, RE arms, Skyjacker shocks, JKS Discos, Superlift Trac bars, Garvin bumpers, Warn 9.5ti, Lockright & trac-lock, 32" BFG KM's, Kilby & warn skids, EOR rocker bars, cowl snorkel)
bcompton is offline   Reply With Quote
Unread 12-29-2005, 12:50 PM   #5
dakuda
Admin, Jeep in Pieces
dakuda's Avatar
See if this helps show how it its attached.
You can do things the right way or the wrong way.
Or you can do it MY way...which is like the wrong way, only faster.
Ramsey Winches | My Gallery | www.dakuda.com
dakuda is offline   Reply With Quote
