Removing "Fuel Pressure Regulator" - JeepForum.com
post #1 of 6 Old 04-11-2011, 06:22 PM Thread Starter
Tassadar
Tassadar's Avatar
Ref: Jeep Wrangler Sport 2002
OK... I have the tank down, wires and pipes securely removed, and full access to the fuel pressure regulator. I also removed the small strap on top of the regulator that holds it down. But now I am stuck, I can rotate it fine (a little bit, since the plastic guides on the frame prevent full rotation). I do no want to force it off with a screw driver (unless I have to). What am I doing wrong?
Carl
PS: Could it be pressure still in area preventing its easy removal? What needs to be done now with the tank removed?
Tassadar is offline
post #2 of 6 Old 04-11-2011, 08:00 PM
Michael_K
Michael_K's Avatar
http://www.dailydriventj.com/fuel_pump.shtml
If you removed the fuel line, there is no pressure in the fuel line.
Check my write up and see if you can figure out what you are doing wrong. It is hard to tell what you are trying to do.
If you are trying to remove the regulator, just pull it off. This is how it looks after the regulator removal.
HTH,
Michael K.
DailyDrivenTJ.com
JUST For Jeep TJ Owners Around the World!
Michael_K is offline
post #3 of 6 Old 04-11-2011, 09:05 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
It just pops out once you have the top steel retainer strap off. I inserted a pair of big flat blade screwdrivers underneath it on both sides and popped it straight up and out.
Jerry Bransford is online now
post #4 of 6 Old 04-11-2011, 09:21 PM Thread Starter
Tassadar
Tassadar's Avatar
Ahhhhhhh, I bet I need to put a little more force into it then, using large screwdrivers. I was afraid to put any force for the fear of breaking something. I was expecting it to just easily slide off after the strap removal
CC
Tassadar is offline
post #5 of 6 Old 04-11-2011, 10:19 PM
Jerry Bransford
Administrator
Plus there is a big fat o-ring at the bottom of the regulator that seats into a groove in the tank opening so that is also holding it.
post #6 of 6 Old 04-13-2011, 04:53 PM Thread Starter
Tassadar
Tassadar's Avatar
UPDATE: The replacement regulator I ordered from the Jeep Dealership worked perfectly. For some reason the one from Autozone is the one that gave me problems going in happily (I think the brand was GP Sorensen).
Thanks all for the great advice.
Carl
Tassadar is offline
Fuel pressure regulator? jerresredyj YJ Wrangler Technical Forum 12 12-28-2010 07:05 AM
fuel pressure regulator Gubni TJ Wrangler Technical Forum 3 12-18-2010 05:49 PM
"Fuel System Pressure Release Procedure" HUH? JBWood05TJ TJ Wrangler Technical Forum 13 03-09-2008 01:27 PM
fuel pressure gage "bouncing" dbikers YJ Wrangler Technical Forum 5 10-30-2007 04:35 PM
fuel pressure regulator mibble98 TJ Wrangler Technical Forum 0 03-15-2007 07:00 AM
