Quantcast Removing the Brake Light Wires.... - JeepForum.com
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Removing the Brake Light Wires....
Old 01-31-2007, 04:12 PM   #1
Capinsano3
When I unplug them and then pull them through the tailgate to remove, how would I reinstall it later? I wouldn't think that I would be able to feed them back through the tailgate...or would I?
Geaux Tigers!
2006 Green Unlimited 4'' Superlift and 33'' Trxus M/Ts
Capinsano3 is offline   Reply With Quote
Old 01-31-2007, 04:15 PM   #2
240M3SRT
If its anything like a 2000 sure you would. I have a 2004 on our lot it has the vented tailgate im about to go look for you.
240M3SRT is offline   Reply With Quote
Old 01-31-2007, 04:17 PM   #3
Capinsano3
Thanks. I understand that I could feed it in the back side of the tailgate but what about getting it to come out the other side. Thats what i dont understand.
Geaux Tigers!
Old 01-31-2007, 04:37 PM   #4
ytodd
phillips screw driver and remove the little plastic cover on the inside of the gate, easy.
ytodd is offline   Reply With Quote
Old 01-31-2007, 04:38 PM   #5
Capinsano3
I understand that, im talking about feeding it through the outer side of the tailgate when reinstalling.
Geaux Tigers!
Old 01-31-2007, 04:52 PM   #6
Skeezer
You have to remove the plastic panel located at the wheelwell (outside the vehicle, above the tire). Then you can feed it right through.
2006 TJ Sport
1995 YJ
2007 JK Sahara Unlimited
www.GrassRootsJeepClub.com
www.GrassRootsJeepClub.proboards80.com
Skeezer is offline   Reply With Quote
Old 01-31-2007, 05:09 PM   #7
BlueFlame
The wires come through a hole in rear tailgate sheet metal. Removing the vent panel lets you reach in to feed them through. They don't come from the body to the tailgate if that's what you're thinking - they have a little 2-button contact plate that makes contact when the tailgate is closed. So if you pull them into the tailgate leave them in there. If you ever want them again you can feed them back out. Nothing else needs to be done.
BlueFlame is offline   Reply With Quote
Glock Forum
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
