Quantcast Removing 3rd brake light... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Removing 3rd brake light...
Old 01-12-2006, 12:58 PM   #1
loudog3114
I cant imagine this would be too hard to do but I was wondering about the wiring. When you remove it, did you ave to cut the wires or do they disconnect somewhere? Also, is the big grey connector from the wheel well to the rear door easy to remove as well?
92 YJ, 35's, 6"
97 Honda CBR1100xx
loudog3114 is offline   Reply With Quote
Old 01-12-2006, 01:13 PM   #2
JoonHoss
1968 C101
when I did mine (IIRC) I did have to cut the wires, but I did them inside the cover of the rear tailgate, so that I could resplice inside if it ever needed to go back on. the plug that the wiring passes through (in the tailgate) has very small holes, and you can't get the wire out throught them.
I pulled all the additional wiring, and put a rubber plug in the hole of the tailgate.
hth
It's hard to say no to yoo-hoo, the name literally beckons...
Don't mind me, I'm just another FNG around here...
JoonHoss is offline   Reply With Quote
Old 01-12-2006, 01:14 PM   #3
98JEEPTJ
2005 WK
The question has come up before if it is legal to remove the 3rd light brake light. Not sure what the answer is but could depend on your state. I wouldn't want you to do it then get a ticket.
OUT WITH THE OLD R.I.P. 98 TJ Sport 4" Procomp lift/adjustable lower control arms and track bar **** Cepek FCII 33x12.50x15/**** Cepek DC-1 wheels
IN WITH THE NEW 05 WK LIMITED EDITION 5.7L
98JEEPTJ is offline   Reply With Quote
Old 01-12-2006, 01:23 PM   #4
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
If I didn't have to, I sure wouldn't remove it... too many drunk/stoned/inattentive drivers out there that need all the help they can get to notice I have applied my brakes.
I had to remove mine due to my ORF spare tire carrier but I will fab up a replacement 3rd brakelight somehow.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Old 01-12-2006, 01:25 PM   #5
emcee5000
You can always buy a $4.99 plug-in trailer hitch brake light. That's what I did to pass.
emcee5000 is offline   Reply With Quote
Old 01-12-2006, 01:30 PM   #6
Jerry Bransford
The light itself isn't the issue, that's easy. It's finding/fabricating a mounting location that is my issue after removing the OE spare tire carrier.
Getting Savvy...
Old 01-12-2006, 01:33 PM   #7
98JEEPTJ
2005 WK
I think he is talking about a light that goes in the reciever...
Old 01-12-2006, 01:35 PM   #8
Jerry Bransford
DOH! I read it too quickly.
Getting Savvy...
Old 01-12-2006, 01:43 PM   #9
Cross Eyed
on my 05, I didn't have to cut the wires. just unplug.
Cross Eyed is offline   Reply With Quote
Old 01-12-2006, 03:11 PM   #10
airduds
FWIW your third brake light works with the Bestop Oversize Spare Tire Carrier (up to a 35" tire).
2000 Sport 4.0/both tops/5sp/4.88s/Dana 44 Truetrac rear/Dana 30 Aussie Locker front/Ramsey 9500 receiver mounted for front and rear/RE 5.5" LA/15"x10" M/T Classic II's/Dunlop Mud Rover 35's/TBT Alumi-Flex tie rod
airduds is offline   Reply With Quote
Old 01-13-2006, 08:16 AM   #11
Blue77
You can 'un-plug' any of the TJ 3rd lights.. you might have to tear apart the door some (not a big deal) .. but the contacts are just two metal plates at the door jam.. you can pull the wires from there
Blue77 is offline   Reply With Quote
Old 01-13-2006, 09:02 AM   #12
bradleyfitz
Assuming the 99 is the same as the 98, and I believe it is, removing the 3rd brake light is easy. Take off your spare, unplug the contacts from inside the Jeep (at the tailgate), remove the rubber gromet on the outside of the tailgate that the wires run through, feed the wires out of the tailgate, unscrew the 3rd brake light from the tire carrier. Done.
98 Sahara, hp44/hp60, warn 5x5.5 premium hub conversion, 4.88, arb's, hydro assist, RE 4.5 SF /w 3.5 springs, Novak / Teraflex SS SYE, currie anti-rock, JKS 1.25" BL, 36" bias iroks, PSC Tube fenders /w 3" flare, PSC Ricochet Rockers, custom rear bumper, btf front bumper / winch plate, warn 9.5ti, full cage, TwistedStitch seats, RCI-2161a fuel cell
bradleyfitz is offline   Reply With Quote
Old 01-13-2006, 09:05 AM   #13
Blue77
Same tailgate on all TJ's (they did a redesign of the metal around '00 but even their replacements for the pre '00s use the 'new' metal), as far as electronics and lock goes...
Old 01-13-2006, 09:29 AM   #14
JeepXJ00
I cut mine from the housing at the plug the light goes into. Then I bought a LED strip from Autozone and relocated it to my tire carrier bumper. Much brighter and much smaller than that big brake light. I shorted it the first time though b/c Chrysler that it would be cool to make their black wire hot and the white wire the ground. Since when do you do that. Oh well a meter got me going in the right direction.
2003 JEEP WRANGLER X-4.0L 5spd
4" Superlift
33x12.5x15 Trxus
JeepXJ00 is offline   Reply With Quote
Old 01-13-2006, 09:58 AM   #15
Flatbroke
Mine unplugged too. The connections were under the plastic cover on the tailgate
Yellow 02 Sport
Originally Posted by XRussoX
Haha
I actually look at a Jeepers nuts to see how informed they are. Ditch your nuts man!
Russo
Flatbroke is offline   Reply With Quote
Glock Forum
