Removing 3in body lift HELP - JeepForum.com
post #1 of 8 Old 04-28-2013, 07:18 PM Thread Starter
wolfeman4
So im looking to downsize to a 1 inch bl or remove my 3 in bl completely. Problem is im 16 and new to this stuff so i pretty much dont know what im doing. I know how to do it, but with a 3in bl there had to be some mods to the steering linkage, gas filler tube, tc linkage, and some others. I need some help on what i should look for and how to fix it. Pictures would be much appreciated!
wolfeman4 is offline
post #2 of 8 Old 04-28-2013, 08:02 PM
Slickfifty11
There should be a block under a joint on your steering shaft i forgot what its called. filler tube will need to be shortened, radiator drop brackets removed and i think thats it if i remember.
Just
Empty
Every
Pocket
Black Jeep Society
Night crew
TJ Owners Club
Jerzey Jeepers
co-founder of
~~GOT MUD CENTRAL NEW JERSEY 4x4 ~~
Slickfifty11 is offline
post #3 of 8 Old 04-29-2013, 07:30 AM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
Your best bet is go to the link below and reverse the steps. Then use second link to install the 1" lift. You can trim the 3" down and just buy new bolts to save money.
http://www.omix-ada.com/instructions/18303.11.pdf
http://www.4x4xplor.com/bl.html
RnEmOvr is offline
post #4 of 8 Old 04-29-2013, 07:41 AM
Ironhead
the front core supports would have to go as well
pics would help us help you as there are many different kits and almost every company goes about all the side stuff differently
Ironhead is online now
post #5 of 8 Old 04-29-2013, 07:41 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
Don't forget the shifter extensions.
TheBoogieman is offline
post #6 of 8 Old 04-29-2013, 07:50 AM
dedYJ
Buy new mounting bolts. Length depends on if you are going back to stock or keeping the 1" BL.
dedYJ is offline
post #7 of 8 Old 04-29-2013, 05:19 PM Thread Starter
wolfeman4
Ive looked around, and ive found some things. i have some pics but i cant upload them because of the post and membership thing. on the radiator there are 4 brackets ill have to take off, and move up to factory holes. the steering linkage looks like it has a little block under the bracket. the gas filler tube has a 3 inch extension in it (its been cut and inserted, do i have to get a new hose?). The tc linkage has a little bracket also that i just have to take off. anything else i should look for?
post #8 of 8 Old 04-29-2013, 05:26 PM
Ironhead
the easiest way to add photos is to upload them to photobucket, or similar, and throw the img link in here
what you described comes with every BL, tall or short, without seeing what you have, there is no way to tell you how to use it
3in lift , body lift help stock back , help please , stock body mount
