Quantcast Remove radiator to change Water pump, Timing chain? - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Remove radiator to change Water pump, Timing chain?
Old 04-28-2009, 09:44 PM   #31
rondak46
I did'nt say I din't like it. You were 0 for 3 on this thread so I though I would try to help you out. Now you are 0 for 4. ;D
rondak46 is offline   Reply With Quote
Old 04-28-2009, 10:17 PM   #32
George Dickel
Restoration Complete
George Dickel's Avatar
Insert the sound of crickets here....
'98 Wrangler Sport, 4.6L Stroker
12 Counterweight 258 Crank (cut snout-casting #3214723), Sealed Power +.030 Hypereutectic Pistons, CompCams 68-231-4, Ported/Polished Head, Edelbrock Header, 24# Venom Injectors, 63mm bored OEM Throttle Body, Port matched Intake, Autolite Platinum plugs, Screamin' Demon Coil, LiveWires Distributor & Wires, Centerforce Clutch, Hurst Shifter, modified Mustang GT Air Cannister - CAI, 18" Magnaflow and 2 1/2" exhaust. Balanced Rotating Assembly.
Yeah, I built it!
'04 Mustang GT, 4.6L
Light modifications
Read more, Post less, Search often
George Dickel is offline   Reply With Quote
Glock Forum
