Remove radiator to change Water pump, Timing chain?
#16 | ||
Dealing with the AC condensor and radiator are not something I am looking forward to, so that was the purpose of the post. After reading some responses and doing more research there are some "while your in there you might as well...." type considerations. A poster above says it can be done in 4 hours. I would count on needing more time than that myself. But I do believe there is performance and reliability to be gained by doing the change at this point. After 9 years and 150k, I think a water pump and TC set swap is a worthwhile pre-emptive venture.
#17 |
World Class Painter
Look at some of rondak46's other posts. I think he is just pulling on some chains, because he is bored.
#18 | |
Thanks Cuder. To be sure, I will throw the symptom I am concerned about out there. I have 4:56 gears and 35 inch tires. When I am going up hills on roads and highways, and I start losing power due to the incline, and if I do not downshift soon enough, I get a massive sneeze from the engine. It seems to be happening before I think it should happen, and I am not sure it should happen after all. So any input regarding that would be helpful. cheers, Mike |
#19 | |
Restoration Complete
'98 Wrangler Sport, 4.6L Stroker 12 Counterweight 258 Crank (cut snout-casting #3214723), Sealed Power +.030 Hypereutectic Pistons, CompCams 68-231-4, Ported/Polished Head, Edelbrock Header, 24# Venom Injectors, 63mm bored OEM Throttle Body, Port matched Intake, Autolite Platinum plugs, Screamin' Demon Coil, LiveWires Distributor & Wires, Centerforce Clutch, Hurst Shifter, modified Mustang GT Air Cannister - CAI, 18" Magnaflow and 2 1/2" exhaust. Balanced Rotating Assembly. Yeah, I built it! '04 Mustang GT, 4.6L Light modifications Read more, Post less, Search often |
#20 | |
#21 | |
Thanks, that is what I am looking for. I really apreciate the advice and I am not pulling anyones chain. cheers, Mike |
#22 |
Oh no... here goes the stroker topic again
Vehicles: 1998 Wrangler Sport w/ 5.2L 318 Swap 1998 Grand Cherokee 5.9 Limited - Kolak Ignition upgrade, K&N CAI, DT Headers w 3" Kolak exhaust/Flowmaster 50/Magnaflow CAT, Front/Rear Baer Drilled/Slotted Rotors, Front/Rear EBC Greenstuff Pads, Alpine CD/MP3/iPod Control Deck, RF 6.5 Power Series Separates My V8 swap thread: http://www.jeepforum.com/forum/f9/my-5-2-v8-swap-618350/ |
#23 |
timing chain check for looseness
simple just pull distributer cap off, turn engine a little forward and watch rotor turn, then turn the engine the other way and the rotor should immediately turn back. If it does then the chain is tight. |
#24 | |
Excellent, Thanks! Do you think this test will be the same or similar given that I have a CPS and not a Distributor? |
#25 |
yah... cuz you can't see the cps turn.
Vehicles: 1998 Wrangler Sport w/ 5.2L 318 Swap 1998 Grand Cherokee 5.9 Limited - Kolak Ignition upgrade, K&N CAI, DT Headers w 3" Kolak exhaust/Flowmaster 50/Magnaflow CAT, Front/Rear Baer Drilled/Slotted Rotors, Front/Rear EBC Greenstuff Pads, Alpine CD/MP3/iPod Control Deck, RF 6.5 Power Series Separates My V8 swap thread: http://www.jeepforum.com/forum/showthread.php?t=618350 |
#26 |
Running Secretly Amok!
You could remove the CPS and watch the pulse ring move though.Same as watching the rotor.
#27 |
Isn't this supposed to be a non-issue on any chain-timed motor that has a tensioner? I can see a problem if the chain only passes through guides, but an automatic adjusting tensioner should keep the chain from ever jumping a tooth.
Honest question here. My dad and I have had some high mileage trucks over the years and never had to replace a timing chain myself on any engine that had one. The only time I can imagine replacing one is complete failure, or jumping time on an engine without a chain tensioner. |
#28 |
Do it right or not at all
![]() Join Date: Jan 2003
Personally I think the idea to replace the timing chain that early for "performance reasons" is pretty silly. Timing chains are well known to be fine, with rare exception, to at least when the engine needs overhauling. The timing chain tensioner pretty well makes any possible minor chain stretch a non-issue. The chain even numping a tooth on the 4.0L is rare enough that it is pretty much a non-issue. To me, all this is much-ado about nothing.
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#29 | |
Yeah, I saw your post (number three); your post directing folks to post number three; and now this one. I wasn't asking if you thought it might be a good idea if I replaced my timng chain. I am trying to believe that you are trying to be helpful but I am losing in that effort. Perhaps you can help with post #18. cheers, |
#30 |
All I can say is that you aren't required to like the opinions offered here on JF. You may get advice and/or opinions you didn't ask for, it happens to me too. That you don't happen to like the opinion I offered is fine with me.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
