Remove Hardtop Glass to Repaint Hardtop?? - JeepForum.com
post #1 of 13 Old 02-02-2010, 07:22 AM Thread Starter
nibblesupreme
I am planning on repainting the hard top on my '01 TJ. Should I remove the glass from the top?
How do you remove the glass? Also, can you remove that weird vent thing? What the hell is the purpose of it anyway..
nibblesupreme is offline
post #2 of 13 Old 02-02-2010, 07:59 AM
InfernoGirl
If it were me, I'd mask off the glass. Remove the vents. They are there to help relieve air pressure, so you can shut your doors with the windows up.
Dirty Mudder seat covers/Steering column covers/spare tire covers
Like my Dirty Mudder FB fan page here:
01 Jeep Wrangler Sport 4.0L, auto
Mine
07 2D Rubicon Flame Red His
InfernoGirl is offline
post #3 of 13 Old 02-02-2010, 08:01 AM
greta
the purpose of the vents is exactly that to vent... the vents also allow free air flow so when you shut your doors the vehicle has a way to release air.
you do not need to take out the glass to paint it... just tape some newspaper over them... there is a good write up somewhere... i will see if i can find it.
greta is offline
post #4 of 13 Old 02-02-2010, 08:03 AM
greta
here you go...
http://www.jeepforum.com/forum/f140/...rd-top-742127/
it is for a yj but the principles remain the same.
greta is offline
post #5 of 13 Old 02-02-2010, 08:05 AM
Cuder
There is a tape you can get at a auto paint store the has a stiff edge. You put the edge under the rubber and pull the rubber up, then stick the other edge to the glass. This makes it so you can get paint under the rubber without leaving a edge of paint next to the rubber.
Cuder is offline
post #6 of 13 Old 02-02-2010, 08:10 AM
DBLJ
DBLJ's Avatar
Mask off the vents. You will probably break them and its a PITA fo glue them again or buy new ones.
Buy my transmission cooler. Derale TJ cooler.
DBLJ is offline
post #7 of 13 Old 02-02-2010, 08:10 AM
greta
also, whenever you paint it, if you do get some spray over just keep some acetone or finger nail polish remover handy, dab some on a tee shirt and wipe the spray over and it will come right off (as long as you do it quick enough).
greta is offline
post #8 of 13 Old 02-02-2010, 08:11 AM
greta
x2
10char
greta is offline
post #9 of 13 Old 02-02-2010, 08:14 AM
DBLJ
DBLJ's Avatar
Also paint it off the Jeep. Some people might not and wonder why they have paint everywhere.
DBLJ is offline
post #10 of 13 Old 02-02-2010, 08:16 AM
greta
unless you painted your jeeps body with krylon fusion also
greta is offline
post #11 of 13 Old 02-02-2010, 09:27 AM
Neil F.
I painted mine. It is easy enough to run tape (blue painters tape) around the edges of the rubber. To cover the glass, I used 8 1/2 x 11 paper sheets (or obviously you can use masking paper or news paper). Put a sheet up to the edge of the rubber and glass and trace the shape of the curve and cut out the paper to match to get the rough outline then seal it with the tape going around the edge. In many places the paper slid between the glass and rubber. All you will need is a few more sheets to cover the middle.
There are a number of tips floating around or that I can give but speaking of the windows. Make sure you spray the recess around the window first to get solid coverage. I did not and some of it was ontop of overspray so I did have some small areas flake off arund the window but it has been easy enough to touch up. I also did the interior to get rid of the ugly non matching white.
The question of actual glass removal has been asked and it is involved to to remove and redo the seal plus you risk damage or breakage.
Neil F. is offline
post #12 of 13 Old 02-02-2010, 09:48 AM Thread Starter
nibblesupreme
The recess? Sorry this is my first rodeo. How do you suggest i position my hardtop when I do this? I was thinking about setting it on a couple of saw horses..
post #13 of 13 Old 02-02-2010, 09:56 AM
Neil F.
(Recess) around the rubber seal on the outside, there is a depression. You have to get a good coat in there. Just look at it. You will see.
I had mine on a board supported by saw horces. I took the back glass off, removed the rubber seal and masked off the opening with tape and newspaper to keep over spray from the interior. (I had pained the interior fist). I also masked and enclosed the front door - door opening
Neil F. is offline
hardtop glass swsscb TJ Wrangler Technical Forum 3 04-29-2008 10:36 PM
hardtop glass izanuff TJ Wrangler Technical Forum 4 02-12-2008 06:18 AM
Glass for Hardtop MeGAMoE TJ Wrangler Technical Forum 6 02-18-2007 05:57 AM
hardtop back glass natedigity TJ Wrangler Technical Forum 12 07-31-2006 05:10 PM
Hardtop/glass Question! yjing YJ Wrangler Technical Forum 6 05-04-2006 10:32 PM
