Remove a body lift? - JeepForum.com
post #1 of 21 Old 06-26-2013, 07:07 AM Thread Starter
bhjohnston
Remove a body lift?
I am sure that this has been addressed many times in the past, but I'll put it in again and maybe someone can direct me to the most appropriate thread!
I helped my son buy a '98 TJ back when it was new, and he gave it to me this Father's Day!! He had installed a 4" Trailmaster suspension lift and a 3" body lift. Sits way to high, so I, at least, want to change the body lift, I think. Tires are 33x12.5, but I don't want to put the money into it to replace those tires (at this time; they have almost the original tread). Can I go back to the OE body height with that suspension and those tires? If so, where can I get a kit with the original body cushions and all of the items that went with them? I have looked into several lift kits, and the 1" kits come with all of the parts, but the OE kits just seem to have the 'rubber'. Thanks for any suggestions. BHJohnston 26JUN2013
bhjohnston is offline
post #2 of 21 Old 06-26-2013, 07:18 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
You'll have plenty of room for 33s either way.All your original rubber mounts should still be on the Jeep unless it's a Daystar BL that replaces the stock rubber mounts.You'll need to address the shifter brackets,radiator fan shroud and gas filler hose being too long.
3" BL instructions.
http://www.quadratec.com/Assets/Installation/10997.pdf
TheBoogieman is offline
post #3 of 21 Old 06-26-2013, 07:19 AM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
4" is enough to run 35s if it is set up right. Here is a kit to replace the OEM pucks. Just so you know though most BLs just add a spacer on the factory pucks. Download a 3" BL install and just reverse the instructions to remove the pucks.
http://www.quadratec.com/products/16058_8X_PG.htm
RnEmOvr is offline
post #4 of 21 Old 06-26-2013, 09:10 AM Thread Starter
bhjohnston
Thanks for the feedbacks! Any idea what the thread sizes and lengths of the OE bolts might be (assuming that there are different bolts at some of the mount locations)? BHJohnston 26JUN2013
post #5 of 21 Old 06-26-2013, 03:40 PM
RnEmOvr
RnEmOvr's Avatar
Somewhere on n here is a picture that has all the bolts and their length and side. Maybe someone has it saved.
RnEmOvr is offline
post #6 of 21 Old 06-26-2013, 04:27 PM
blubaru2002
Does your jeep have a MML?
Originally Posted by Patrick Bateman
I have to return some video tapes.
blubaru2002 is online now
post #7 of 21 Old 06-26-2013, 04:40 PM
TheOtherMe
Wish you were closer. I have all of the original bolts sitting in my garage. I'd give em to you, but shipping would probably cost more than buying the bolts.
TheOtherMe is offline
post #8 of 21 Old 06-26-2013, 04:40 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Stock body mount bolts:
Wheelin98TJ is offline
post #9 of 21 Old 06-26-2013, 07:22 PM
kuruma
Yeah you'll be fine with 33's. Drop it down to a 1 inch and go for a tummy tuck. Highly suggest it to get rid of ya shovel.
kuruma is offline
post #10 of 21 Old 06-26-2013, 07:34 PM
RnEmOvr
RnEmOvr's Avatar
They will all fit in a small flat rate box that cost $5.40 to ship anywhere.
RnEmOvr is offline
post #11 of 21 Old 07-01-2013, 12:43 PM Thread Starter
bhjohnston
Thanks for everyone's help on this. I am new to Jeep, but I do know one thing, this Wrangler really drives squirrely (sp?). While the body lift has raised the center of gravity, I don't think that the lift is causing the driveability issues. Does anyone know of persons or businesses in NW South Carolina that might be able to see what I have and give me some clues? 'Clemson 4 Wheel Center' has been suggested at this end. BHJohnston 01JUL2013
post #12 of 21 Old 07-01-2013, 12:54 PM
RnEmOvr
RnEmOvr's Avatar
If you can decribe what you mean by "squirrely" then we can help.
RnEmOvr is offline
post #13 of 21 Old 07-01-2013, 01:19 PM Thread Starter
bhjohnston
Steering seems 'loose'. Kind of like in older cars when the toe-in was not correct. And, with the added height (3" body lift and 4" suspension lift), the body seems to 'roll'. Don't want to take turns too fast! I am probably not describing this accurately and think that someone with 'know-how' really needs to drive it to see what I am talking about. My son said that the steering changed quite a bit after he put the steel wheels and 33x12.5 tires on it. He claims that he has changed steering dampers a couple of times, but with no obvious change. I think that there is more to it than just dampening the steering. BHJohnston 01JUL2013
post #14 of 21 Old 07-01-2013, 01:23 PM
RnEmOvr
RnEmOvr's Avatar
You very well could have loose steering parts. I would start by checking the tie-rod ends and all the bushings in the front end. Search death wobble and you will see what parts I am refering to. You may have DW that is being cover by the damper. The damper is not the fix or the cause. As for the body roll, does it have front and/or rear sway bars?
RnEmOvr is offline
post #15 of 21 Old 07-01-2013, 01:46 PM Thread Starter
bhjohnston
I have only had the Jeep for a short time and I have not crawled under to see what things look like. I'll do that and try to let you know what I see. I do know that my son had some place install the lift and suspension kits and he does not seem to know all that was done. BHJohnston 01JUL2013
